Saltar al contenido principal
iPad Mini 3 Wi-Fi LCD Shield Plate Replacement
Aviso: Estás editando una guía de requisitos previos. Cualquier cambio que realices afectará a todas las 48 guías que incluyen este paso.
Inglés
Holandés
Paso 8
iPad Mini 3 Wi-Fi LCD Shield Plate Replacement: paso 0, imagen 1 de 3 iPad Mini 3 Wi-Fi LCD Shield Plate Replacement: paso 0, imagen 2 de 3 iPad Mini 3 Wi-Fi LCD Shield Plate Replacement: paso 0, imagen 3 de 3
  • Take the first pick you inserted and slide it up toward the top corner of the iPad.
  • If you can see the tip of the opening pick through the front glass, don't panic—just pull the pick out a little bit. Most likely, everything will be fine, but try to avoid this as it may deposit adhesive on the front of the LCD that is difficult to clean off.
Insertar traducción aquí
