Saltar al contenido principal
iPad Mini CDMA Front Panel Assembly Replacement
Aviso: Estás editando una guía de requisitos previos. Cualquier cambio que realices afectará a todas las 5 guías que incluyen este paso.
Inglés
Holandés
Paso 2
iPad Mini CDMA Front Panel Assembly Replacement, Front panel preparation: paso 0, imagen 1 de 2 iPad Mini CDMA Front Panel Assembly Replacement, Front panel preparation: paso 0, imagen 2 de 2
  • This is a good time to power on your iPad and test all functions before you seal the display in place. Be sure to power your iPad back down completely before you continue.
  • If you're installing a new front panel assembly, it may need the following preparation:
  • Peel the large clear plastic liner off of the inside of the glass.
  • Peel any blue plastic backings covering the adhesive around the perimeter of the front panel assembly.
  • Once removed, the adhesive strips will be exposed. Don't remove these backings until you're ready to install the front panel assembly.
  • Don't remove any copper coverings from the outlined region, such as yellow kapton tape or black electrical tape.
  • Ensure the glass panel is free of fingerprints and grime before installing it on your device.
Insertar traducción aquí
