Saltar al contenido principal
iPhone 5s Logic Board Replacement
Aviso: Estás editando una guía de requisitos previos. Cualquier cambio que realices afectará a todas las 7 guías que incluyen este paso.
Inglés
Holandés
Paso 6
iPhone 5s Logic Board Replacement: paso 0, imagen 1 de 1
  • Remove the following screws from the logic board:
  • One 2.4 mm Phillips #000 screw
  • This screw also holds a small metal contact beneath the logic board. It's held in place underneath a plastic bracket, but if you see it slipping out, refer to this step to remove it.
  • Two 2.3 mm Phillips #000 screws
  • Four 2.8 mm standoff screws
  • Standoff screws are best removed using a standoff screwdriver or bit.
  • In a pinch, a small flathead screwdriver will do the job—but use extra caution to ensure it doesn't slip and damage surrounding components.
Insertar traducción aquí
