Saltar al contenido principal
iBook G4 14" 933 MHz-1.33 GHz Logic Board Replacement
Inglés
Holandés
Paso 4
iBook G4 14" 933 MHz-1.33 GHz Logic Board Replacement: paso 0, imagen 1 de 1
  • The cable you're about to remove is very fragile - do not pull directly on the wires. Instead, try to pry up the connector directly, using a spudger or a small flathead screwdriver if necessary.
  • Disconnect the microphone cable at the front of the computer, between the left side of the hard drive and the metal framework.
Insertar traducción aquí
