Aviso: Ahora estás editando un requisito previo de la guía que estabas viendo. Cualquier cambio que realices afectará a todas las 6 guías que incluyen este paso.
Traduciendo paso 2
Paso 2
Remove the stretch release adhesive
Use tweezers to pull on the battery adhesive strip's pull tab until you can grip it with your fingers.
While holding the battery in place, pull the strip out slowly and steadily at a low angle. Give it plenty of time to stretch and un-stick from under the battery.
If the adhesive strip breaks off, try to retrieve it using your fingers and continue pulling—but don’t pry under the battery.
[title] Remove the stretch release adhesive | |
+ | [* icon_note] The next two steps show how to remove a battery that's secured by stretch release adhesive. |
[* black] Use [product|IF145-020|tweezers] to pull on the battery adhesive strip's pull tab until you can grip it with your fingers. | |
[* black] While holding the battery in place, pull the strip out slowly and steadily at a low angle. Give it plenty of time to stretch and un-stick from under the battery. | |
[* icon_note] You can also wrap the adhesive strip around a spudger and "roll" it for a more consistent pull. | |
[* black] If the adhesive strip breaks off, try to retrieve it using your fingers and continue pulling—but don’t pry under the battery. | |
[* icon_note] If you can't retrieve a strip, don't worry! Remove as much adhesive as possible and skip down two steps for an alternate method. |
