Saltar al contenido principal
HP All-in-one PC Model 24 Motherboard Replacement
Inglés
Holandés
Paso 13
HP All-in-one PC Model 24 Motherboard Replacement, Removing the Ribbon Cable from the Power Button: paso 0, imagen 1 de 2 HP All-in-one PC Model 24 Motherboard Replacement, Removing the Ribbon Cable from the Power Button: paso 0, imagen 2 de 2
  • Release the Cable's Connector: Carefully release the ribbon cable from its connector on the motherboard. The connector has a latch, gently lift it up to release the cable. The same way as in step 6.
  • Disconnect the Ribbon Cable: Once the latch is released, gently pull the ribbon cable out its connector.
  • Note: Be sure not to pull on the cable too forcefully to avoid damaging the cable or the connector.
Insertar traducción aquí
