Saltar al contenido principal
Xbox Series X USB and Pair Button Board Replacement
Aviso: Estás editando una guía de requisitos previos. Cualquier cambio que realices afectará la guía que incluye este paso.
Inglés
Holandés
Traduciendo paso 2
Paso 2
Xbox Series X USB and Pair Button Board Replacement, Remove the USB board: paso 0, imagen 1 de 3 Xbox Series X USB and Pair Button Board Replacement, Remove the USB board: paso 0, imagen 2 de 3 Xbox Series X USB and Pair Button Board Replacement, Remove the USB board: paso 0, imagen 3 de 3
  • Use your fingers to lift the skinnier side of the board.
  • Pull the board away from the enclosure and out from under its clips to remove it.
  • Check if your replacement board comes with a cable. If it doesn't, remove the cable from your original board and transfer it to your replacement.
  • During reassembly, first insert the board under its clips on the wider edge of the enclosure and then lay the board into place.
Insertar traducción aquí
