Saltar al contenido principal
Center Chassis Removal (Power Supply Attached)
Aviso: Estás editando una guía de requisitos previos. Cualquier cambio que realices afectará a todas las 5 guías que incluyen este paso.
Inglés
Español
Paso 2
Center Chassis Removal (Power Supply Attached): paso 0, imagen 1 de 3 Center Chassis Removal (Power Supply Attached): paso 0, imagen 2 de 3 Center Chassis Removal (Power Supply Attached): paso 0, imagen 3 de 3
  • Grip the base of the interconnect cable connector with your fingers.
  • Depress each side of the connector to unlock the cable locking tabs.
  • With the locking tabs depressed, grip the edges of the interconnect cable and pull it straight out of the connector to disconnect it.
  • With the locking tabs depressed correctly, the interconnect cable will slide out with very little force.
  • During reassembly, the interconnect cable should "snap" into place when fully inserted.
Insertar traducción aquí
