Saltar al contenido principal
Extracción de la placa madre
Aviso: Estás editando un prerrequisito para la guía que estabas viendo. Cualquier cambio que realices afectará a la guía que incluye este paso.
Inglés
Español
Traduciendo paso 5
Paso 5
Main Board Removal, Remove the main board: paso 0, imagen 1 de 2 Main Board Removal, Remove the main board: paso 0, imagen 2 de 2
  • Remove the main board, flip it over, and carefully lay it on a clean work surface, so the APU is facing up.
  • Don't press the board against your work surface, or you may damage fragile components.
  • During reassembly:
  • Make sure all cables that connect to the board are out of the way so they don't get trapped underneath.
  • Carefully flip the board over so the APU is on the bottom, making sure no liquid metal spills.
  • Keep the board level and lower it into place.
Quitala placa principal, dale la vuelta y colócala sobre un paño limpio, de modo que la APU quede hacia arriba.
Durante el reensamblaje:
Asegúrate de que todos los cables que se conectan a la placa estén apartados para que no queden atrapados debajo.
Voltee con cuidado la placa para que la APU quede en la parte inferior, asegurándose de que no se derrame metal líquido.
Mantén la tabla nivelada y bájala hasta su lugar.
[title] Remove the main board
-[* black] Remove the main board, flip it over, and lay it on a clean cloth, so the [link|https://guide-images.cdn.ifixit.com/igi/WOcnu1QxQsbncJFs.full|APU|new_window=true] is facing up.
+[* black] Remove the main board, flip it over, and carefully lay it on a ''clean'' work surface, so the [link|https://guide-images.cdn.ifixit.com/igi/WOcnu1QxQsbncJFs.full|APU|new_window=true] is facing up.
+ [* icon_caution] Don't press the board against your work surface, or you may damage fragile components.
[* icon_reminder] During reassembly:
[* black] Make sure all cables that connect to the board are out of the way so they don't get trapped underneath.
[* black] ''Carefully'' flip the board over so the APU is on the bottom, making sure no liquid metal spills.
[* black] Keep the board level and lower it into place.
