Saltar al contenido principal
Asus VivoBook Flip 14 Hard Drive Replacement
Inglés
Español
Paso 3
Asus VivoBook Flip 14 Hard Drive Replacement, Back Cover: paso 0, imagen 1 de 3 Asus VivoBook Flip 14 Hard Drive Replacement, Back Cover: paso 0, imagen 2 de 3 Asus VivoBook Flip 14 Hard Drive Replacement, Back Cover: paso 0, imagen 3 de 3
Back Cover
  • Starting from the power button area, insert a flat pry tool between the side and back of the laptop, and lever the back away from the rest of the case.
  • These photographs show a metal pry tool, but a plastic tool or spudger is preferred to avoid shorting the electronics inside.
  • Continue around the rear (hinge side) of the laptop, ensuring that you insert the tool at the proper seam.
  • Once the sides and rear clips are pried free, the back can be gently swung away to unclip the front of the back.
  • Ensure that you do not insert your pry tool too far into the case, particularly under the front area, to avoid damaging the lithium battery. Puncturing, deforming, or scratching the battery could cause it to leak or explode.
Insertar traducción aquí
