Saltar al contenido principal
Chevrolet SS Sedan Rear Strut Removal
Aviso: Estás editando una guía de requisitos previos. Cualquier cambio que realices afectará la guía que incluye este paso.
Inglés
Español
Traduciendo paso 8
Paso 8
No hay imagen
Re-assembly Notes
  • The order that I've found which makes re-assembly the easiest is:
  • Install the strut-to-LCA nut/bolt, but keep them loose.
  • Install the strut-to-body bolts, but keep them loose
  • Install the LCA-to-knuckle nut/bolt, with the help of a jack and prybar. This step is probably the most difficult.
  • Get all nuts/bolts tightened snugly.
  • Raise the LCA with the jack to "simulate" the car sitting on the ground, compressing the suspension. Then, torque everything to specifications.
Insertar traducción aquí
