Saltar al contenido principal
iFixit utiliza cookies para mejorar la funcionalidad del sitio, analizar el tráfico y personalizar los anuncios. Al utilizar nuestro sitio, aceptas nuestro uso de cookies y nuestra Política de privacidad.
Dell Latitude E7450 Hard Drive Replacement
Inglés
Español
Traduciendo paso 1
Paso 1
No hay imagen
Remove battery and base cover
  • Before performing this task, make sure you turn off the computer and disconnect every external device from the machine, be it USB devices, Displays, Power, or anything else.
  • Slide the release latch to unlock the battery before removing it. To remove the base cover, you should remove the Philips head screw on either end of the laptop in the battery compartment, before lifting it up from the screw hole side.
Insertar traducción aquí
