Saltar al contenido principal
Desmontaje de Apple Watch Series
Inglés
Español
Paso 8
Apple Watch Series 6 Teardown: paso 0, imagen 1 de 3 Apple Watch Series 6 Teardown: paso 0, imagen 2 de 3 Apple Watch Series 6 Teardown: paso 0, imagen 3 de 3
  • Fused display up top, fused sensor array below—we won't find anything but broken pieces if we bust this apart, so let's switch on those X-rays from Creative Electron again for a better look.
  • The dark rectangle in the center is a dense magnet for centering the charger (and may also help wick away heat from the S6 package). It's surrounded by the control board for the down-firing LEDs and sensors, and the ropey coils of copper for the inductive charger.
  • And here's the (reassembled) pulse oximeter communicating with aliens lighting up in Christmas-y fashion!
  • By shining red, green, and infrared light into your skin, then sensing via photodiode how it bounces back, the watch can tell how oxygenated your blood is (redder means more oxygen).
  • Low blood oxygen levels (hypoxemia) can be an indication of COVID-19 or other serious medical issues.
  • The Apple Watch doesn't track body temp like the Oura Ring 2 does. But while both measurements are informative, neither is meant to provide hospital-grade certainty.
  • As a reminder, we're not health experts—so read up! Find out more about how blood oxygen tracking works at CNET, or a lot more at the Respiratory Medicine journal.
Pantalla fusionada en una pieza en la parte superior, ensamblaje del sensor fusionado en una pieza en la base. Si intentamos abrirla, no encontraremos nada más que trozos rotos, así que encendamos esos Rayos X de Creative Electronpara ver mejor
El rectángulo oscuro en el centro es un imán denso para centrar el cargador ( y también puede ayudarba apsorber el cargador del paquete S6). Está rodeado por el tablero de control para LED y sensores de disparo descendentes, y las bobinas de cobres para el cargador inductivo.
Y aquí está nuestro oxímetro de pulso encendiéndose como luces de Navidad.
Al brillar luces rojas, verdes e infrarrojas en su piel, y luego al observar por medio de un fotodiodo cómo rebotan, el sensor puede decir cuán oxigenada está tu sangre (más roja significa más oxígeno).
Los bajos niveles de oxígeno en la sangre (hipoxemia) pueden ser un indicio de COVID-19 u otros problemas médicos graves.
El Apple Watch no registra la temperatura corporal como lo hace el Oura Ring 2. Pero aunque es bueno saberlo, ninguno de los dos es lo suficientemente preciso para tener certeza.
Como recordatorio de que no somos expertos en salud, ¡así que lean! Descubra más sobre cómo funciona el seguimiento del oxígeno en la sangre en CNET, o mucho más en la Revista de Medicina Respiratoria.
