Saltar al contenido principal
Desmontaje de Apple Watch Series
Inglés
Español
Paso 6
Apple Watch Series 6 Teardown: paso 0, imagen 1 de 3 Apple Watch Series 6 Teardown: paso 0, imagen 2 de 3 Apple Watch Series 6 Teardown: paso 0, imagen 3 de 3
  • Like most brains, the grey matter in this Series 6 is pretty inscrutable: it's encased in hardened resin, as per usual, making further exploration extremely difficult.
  • Update: Unless you have an X-ray machine, that is! Here's an inside look at the S6 package. If you're wondering what all the tiny shapes are, check out the original Apple Watch X-ray teardown for an explainer.
  • There are a few more conventional ICs piggybacked onto the package, and we can at least spot a Skyworks chip marked 239-7. The other chips are more mysterious, and none is an exact match for the U1 chip we found in last year's iPhones.
  • It was probably too much to ask for a labeled U1 package, but there has been more obvious printing in the past.
  • Sans-brains, we can see the Series 6 frame has a slightly modified footprint with a narrower lip for the adhesive gasket, which is now carefully routed around the band mechanism.
  • The modified case and lack of Force Touch gasket probably accounts for the fact that this year's model is a hair thinner, with overall thickness at 10.4 mm (down from 10.74 mm last year).
  • Apple somehow packed more battery and more Taptic Engine into a (barely) smaller design. Impressive!
Como la mayoría de los cerebros, la materia gris del Serie 6 es bastante inescrutable: está encapsulada en resina endurecida, como de costumbre, lo que hace extremadamente difícil una mayor exploración.
Actualización: A menos que tengas una máquina de rayos X, ¡eso es! Aquí hay un vistazo al interior del paquete S6. Si te preguntas qué son todas esas pequeñas formas, mira el desmontaje de rayos X del reloj Apple original para que te lo explique.
Hay unos pocos CI más convencionales en el paquete, y al menos podemos ver un chip de Skyworks marcado como 239-7. Los otros chips son más misteriosos, y ninguno coincide exactamente con el chip U1 que encontramos en los iPhones del año pasado.
Probablemente fue demasiado pedir un paquete etiquetado U1, pero ha habido impresiones más obvias en el pasado.
Sin cerebro, podemos ver que el marco de la Serie 6 tiene una huella ligeramente modificada con un labio más estrecho para la junta adhesiva, que ahora está cuidadosamente dirigida alrededor del mecanismo de la banda.
La caja modificada y la falta de junta de Force Touch probablemente explica el hecho de que el modelo de este año sea un poquitín más delgado, con un grosor total de 10.4 mm (por debajo de los 10.74 mm del año pasado).
Apple de alguna manera empacó más batería y más Motor Táptico en un diseño (apenas) más pequeño. ¡Impresionante!
