Traduciendo paso 1
Paso 1
Remove the ten 3mm T5 Torx screws located on the outer perimeter of the device.
Use a Phillips #00 screwdriver to remove the two 10mm screws under the flip up plate.
Remove the rear panel using a plastic spudger. Its easiest to start from the top and work your way to the bottom.
