Saltar al contenido principal
Xiaomi Mi Watch Teardown
Inglés
Español
Traduciendo paso 12
Paso 12
Xiaomi Mi Watch Teardown, Final Thoughts: paso 0, imagen 1 de 1
Final Thoughts
  • The Xiaomi Mi Watch earns a 5 out of 10 on our repairability scale (10 is the easiest to repair):
  • The bands are easy to remove and replace.
  • Battery replacement is fairly straightforward once you're inside, but the motherboard must be removed for access.
  • Most components are modular and can be replaced separately, except for the circuit board at the bottom—which is secured with plastic rivets.
  • Opening the watch by removing the screen is possible, but difficult—and will most likely result in cosmetic damage.
Insertar traducción aquí
