Saltar al contenido principal
HP Chromebook 11 G6 EE Screen Replacement
Inglés
Español
Traduciendo paso 1
Paso 1
HP Chromebook 11 G6 EE Screen Replacement, Remove the plastic frame: paso 0, imagen 1 de 1
  • Use a plastic pick or spudger around the edges of the bezel to pop the clips loose.
  • If the LCD is already damaged and you're going to replace it, you can use the pick to break the adhesive along the inside edge of the bezel. If you want to preserve the LCD, use a heat gun to soften the adhesive before removing the bezel.
Insertar traducción aquí
