Saltar al contenido principal
Nintendo Wii 2011 Bluetooth and Wi-Fi Boards Replacement
Inglés
Holandés
Traduciendo paso 3
Paso 3
No hay imagen
  • Using the soldering kit, heat and take the solder off the wires connecting the Bluetooth and Wi-Fi boards.
  • Using the soldering kit re-solder the wiring back onto the same area it was removed from the circuit board.
  • Use caution when soldering as the iron is hot. If you are unfamiliar with solder, check out the article on the topic.
Insertar traducción aquí
