Saltar al contenido principal
Dell XPS 15 9575 Heat Sink Replacement
Aviso: Estás editando una guía de requisitos previos. Cualquier cambio que realices afectará a todas las 2 guías que incluyen este paso.
Inglés
Holandés
Traduciendo paso 3
Paso 3
Dell XPS 15 9575 Heat Sink Replacement: paso 0, imagen 1 de 2 Dell XPS 15 9575 Heat Sink Replacement: paso 0, imagen 2 de 2
  • Wedge the plastic opening pick in between the edge of the heat sink and the aluminum perimeter with care not to scratch the CPU beneath.
  • Gently pry up on the heat sink until it is loose enough for you to remove. Then grab and remove the heat sink.
  • If it does not work in the first position that you tried, try another. Do not pry too much in one position because it could damage the components beneath the heat sink.
  • Clean and Reapply the Thermal Paste during reinstallation.
Insertar traducción aquí
