Saltar al contenido principal
iPad Mini 3 Wi-Fi LCD Shield Plate Replacement
Aviso: Estás editando una guía de requisitos previos. Cualquier cambio que realices afectará a todas las 16 guías que incluyen este paso.
Inglés
Holandés
Paso 29
iPad Mini 3 Wi-Fi LCD Shield Plate Replacement: paso 0, imagen 1 de 2 iPad Mini 3 Wi-Fi LCD Shield Plate Replacement: paso 0, imagen 2 de 2
  • Do not attempt to fully remove the LCD. It is still connected to the iPad by several cables at the home button end. Lift only from the front-facing camera end.
  • Insert the flat end of a spudger under the LCD between it and the LCD shield plate and lift gently.
  • Be very careful not to get the spudger under the shield plate. It must be between the LCD and the shield.
  • Even bending the LCD slightly can permanently damage it, so be extremely careful as you lift.
Insertar traducción aquí
