Saltar al contenido principal
Repara tus cosas
Derecho a Reparar
Partes y Herramientas
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 42 guías que incluyan este paso.
Inglés
Español
Paso 7
The LCD is glued to the metal LCD shield plate behind it along the top, left, and right edges. In order to safely loosen this adhesive, you'll be using a guitar pick to shift the LCD a couple of millimeters left and right several times. Insert a guitar pick into the gap between the LCD and rear case, near the top of the left side of the LCD.
  • The LCD is glued to the metal LCD shield plate behind it along the top, left, and right edges. In order to safely loosen this adhesive, you'll be using a guitar pick to shift the LCD a couple of millimeters left and right several times.
  • Insert a guitar pick into the gap between the LCD and rear case, near the top of the left side of the LCD.
  • Bend the pick slightly away from the iPad, just enough to spread the gap between the LCD and rear case.
Insertar traducción aquí
