Saltar al contenido principal
Repara tus cosas
Derecho a Reparar
Partes y Herramientas
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 9 guías que incluyan este paso.
Inglés
Español
Traduciendo paso 2
Paso 2
With the tip of a spudger, peel up the larger piece of tape covering both antenna cables near the bottom of the rear case. Do not try to remove this piece of tape; it is wrapped around the top antenna cable. Do not try to remove this piece of tape; it is wrapped around the top antenna cable.
  • With the tip of a spudger, peel up the larger piece of tape covering both antenna cables near the bottom of the rear case.
  • Do not try to remove this piece of tape; it is wrapped around the top antenna cable.
Insertar traducción aquí
