Saltar al contenido principal
iPad Mini CDMA LCD Assembly Replacement
Aviso: Estás editando una guía de requisitos previos. Cualquier cambio que realices afectará a todas las 42 guías que incluyen este paso.
Inglés
Holandés
Paso 7
iPad Mini CDMA LCD Assembly Replacement: paso 0, imagen 1 de 2 iPad Mini CDMA LCD Assembly Replacement: paso 0, imagen 2 de 2
  • The LCD is glued to the metal LCD shield plate behind it along the top, left, and right edges. In order to safely loosen this adhesive, you'll be using a guitar pick to shift the LCD a couple of millimeters left and right several times.
  • Insert a guitar pick into the gap between the LCD and rear case, near the top of the left side of the LCD.
  • Bend the pick slightly away from the iPad, just enough to spread the gap between the LCD and rear case.
Insertar traducción aquí
