Saltar al contenido principal
iFixit utiliza cookies para mejorar la funcionalidad del sitio, analizar el tráfico y personalizar los anuncios. Al utilizar nuestro sitio, aceptas nuestro uso de cookies y nuestra Política de privacidad.
nikon s3700 LCD Display Screen Replacement
Aviso: Estás editando una guía de requisitos previos. Cualquier cambio que realices afectará la guía que incluye este paso.
Inglés
Español
Traduciendo paso 2
Paso 2
nikon s3700 LCD Display Screen Replacement, Replace LCD: paso 0, imagen 1 de 3 nikon s3700 LCD Display Screen Replacement, Replace LCD: paso 0, imagen 2 de 3 nikon s3700 LCD Display Screen Replacement, Replace LCD: paso 0, imagen 3 de 3
Replace LCD
  • Remove Rear casing.
  • With a thin blade, gently lift the top tight hand side of the buttons board releasing a peg from a hole on the midframe below. Whilst doing so, gently push on the top left hand side in order to release the buttons board from a clip. At the same time, the bottom left hand corner wil be released from another clip.
  • Flip over rear buttons board to expose LCD ZIF clamp.
  • Flip open the clamp of the ZIF connector and slide the ribbon cable out. (The connector may have a piece of sticky tape over it. Removing this may well open the connector clamping bar.)
  • The ZIF clamp is very fragile so please use caution when releasing the ZIF clamp. It breaks easily.
  • Remove the LCD.
Insertar traducción aquí
