Saltar al contenido principal
the Nokia 6230b Camera Replacement
Job Jao
Job Jao y 4 otros contribuidores
Última actualización: January 28, 2014
5 minuto
Moderado
Introducción
Ir al paso 1
The camera is attached to the motherboard in your phone. A T6 screwdriver is needed to access the camera.
Qué necesitas
  1. the Nokia 6230b Camera Replacement, Back Cover: paso 1, imagen 1 de 1
    • Press down the button on the back panel.
  2. the Nokia 6230b Camera Replacement: paso 2, imagen 1 de 2 the Nokia 6230b Camera Replacement: paso 2, imagen 2 de 2
    • Push the back cover upwards.
  3. the Nokia 6230b Camera Replacement: paso 3, imagen 1 de 2 the Nokia 6230b Camera Replacement: paso 3, imagen 2 de 2
    • Remove the back cover from the phone.
  4. the Nokia 6230b Camera Replacement, Front Cover: paso 4, imagen 1 de 1
    • Press the silver button on the top of the phone.
  5. the Nokia 6230b Camera Replacement: paso 5, imagen 1 de 1
    • Slide your thumbnail down the case seam to separate the rest of the case.
  6. the Nokia 6230b Camera Replacement: paso 6, imagen 1 de 1
    • Gently remove the case.
    • Careful! Do not bend the plastic tabs.
  7. the Nokia 6230b Camera Replacement, Motherboard: paso 7, imagen 1 de 2 the Nokia 6230b Camera Replacement, Motherboard: paso 7, imagen 2 de 2
    • Using a T6 Torx Screwdriver, unscrew and remove the six screws shown in the picture.
  8. the Nokia 6230b Camera Replacement: paso 8, imagen 1 de 2 the Nokia 6230b Camera Replacement: paso 8, imagen 2 de 2
    • Remove the panel that covers the motherboard.
    • If replacing the speaker, stop at this step and skip forward to the first step of the speaker guide.
  9. the Nokia 6230b Camera Replacement: paso 9, imagen 1 de 1
    • Remove the LCD screen frame.
  10. the Nokia 6230b Camera Replacement: paso 10, imagen 1 de 1
    • Remove the motherboard.
  11. the Nokia 6230b Camera Replacement, Camera: paso 11, imagen 1 de 1
    • Locate the camera on the circuit board.
  12. the Nokia 6230b Camera Replacement: paso 12, imagen 1 de 1
    • Place the circuit board on a firm, static free surface (no cloth/carpet).
    • NOTE: The circled alignment notch points to the left.
  13. the Nokia 6230b Camera Replacement: paso 13, imagen 1 de 1
    • Pull the left holding tabs to the left.
  14. the Nokia 6230b Camera Replacement: paso 14, imagen 1 de 1
    • Lift out the left side of the camera.
  15. the Nokia 6230b Camera Replacement: paso 15, imagen 1 de 1
    • Pull the right holding tabs to the right.
  16. the Nokia 6230b Camera Replacement: paso 16, imagen 1 de 1
    • Pull camera off of board.
Conclusión
2 personas más completaron esta guía.
Job Jao
Miembro Desde 10/08/10
37 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 3-27, Regan Fall 2010 Miembro de Cal Poly, Team 3-27, Regan Fall 2010
CPSU-REGAN-F10S3G27
4 Miembros
9 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 1,906
