Saltar al contenido principal
iRobot Roomba 630 Side Brush Motor Replacement
Jabari Baptiste
Jabari Baptiste y 9 otros contribuidores
Última actualización: June 30, 2023
20 - 40 minutos
Moderado
Introducción
Ir al paso 1
This guide explains how to replace the side brush motor on the iRobot Roomba 630. The motor may need to be replaced if it is damaged or defective.
The side brush motor attaches to the side brush to make it spin, which helps sweep dirt and debris from hard-to-reach corners into the vacuum's suction. Before using this guide, you may first check whether debris or hair is caught in the brush or motor, preventing the motor from spinning. You might also check to see if the motor is poorly lubricated, which can prevent it from spinning. If the side brush and motor are clear of debris but the motor is still not working, the motor may be defective.
Qué necesitas
iFixit gana una comisión si finalizas una compra usando estos enlaces.
  1. iRobot Roomba 630 Side Brush Motor Replacement, Side Brush Motor: paso 1, imagen 1 de 2 iRobot Roomba 630 Side Brush Motor Replacement, Side Brush Motor: paso 1, imagen 2 de 2
    • Flip the Roomba over so that the wheels are facing upwards.
    • Unscrew the 6 mm screw from the yellow side brush using a Phillips #2 screwdriver.
  2. iRobot Roomba 630 Side Brush Motor Replacement: paso 2, imagen 1 de 2 iRobot Roomba 630 Side Brush Motor Replacement: paso 2, imagen 2 de 2
    • Remove the four 10.1 mm screws from the back cover using a Phillips #2 screwdriver.
    • Lift the back cover off to access the gear box.
  3. iRobot Roomba 630 Side Brush Motor Replacement: paso 3, imagen 1 de 3 iRobot Roomba 630 Side Brush Motor Replacement: paso 3, imagen 2 de 3 iRobot Roomba 630 Side Brush Motor Replacement: paso 3, imagen 3 de 3
    • Remove the three outer 15 mm screws that hold down the gearbox using a Phillips #2 screwdriver.
    • Remove the middle 15 mm screw to release the gearbox using a tri-point Y0 screwdriver.
    • Lift the blue side brush gear box out.
  4. iRobot Roomba 630 Side Brush Motor Replacement: paso 4, imagen 1 de 2 iRobot Roomba 630 Side Brush Motor Replacement: paso 4, imagen 2 de 2
    • Pry the top of the gear box off.
    • Check for debris in the gear box and clean it out if needed.
  5. iRobot Roomba 630 Side Brush Motor Replacement: paso 5, imagen 1 de 3 iRobot Roomba 630 Side Brush Motor Replacement: paso 5, imagen 2 de 3 iRobot Roomba 630 Side Brush Motor Replacement: paso 5, imagen 3 de 3
    • Remove the screws holding the motor in place using a Phillips #2 screwdriver.
    • Pull the old motor out.
Conclusión
4 personas más completaron esta guía.
Jabari Baptiste
Miembro Desde 10/03/17
485 Reputación
3 Guías creadas
Equipo
USF Tampa, Team S5-G3, Walkup Fall 2017 Miembro de USF Tampa, Team S5-G3, Walkup Fall 2017
USFT-WALKUP-F17S5G3
4 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 22
Ultimos 30 días: 32
Todo El Tiempo: 2,244
