Saltar al contenido principal
ZTE ZFive G LTE Volume and Power Button Replacement
Julian Mendoza
Julian Mendoza y 3 otros contribuidores
Última actualización: May 7, 2024
10 - 15 minutos
Moderado
Introducción
Ir al paso 1
This is not a guide for replacing the switch assembly, only for replacing the plastic covers to the buttons.
Qué necesitas
Herramientas
Ver más…
  1. ZTE ZFive G LTE Volume and Power Button Replacement, Volume and power button: paso 1, imagen 1 de 3 ZTE ZFive G LTE Volume and Power Button Replacement, Volume and power button: paso 1, imagen 2 de 3 ZTE ZFive G LTE Volume and Power Button Replacement, Volume and power button: paso 1, imagen 3 de 3
    • Remove back cover of the device from the crease of the bottom left corner using opening tool or fingernail.
  2. ZTE ZFive G LTE Volume and Power Button Replacement: paso 2, imagen 1 de 2 ZTE ZFive G LTE Volume and Power Button Replacement: paso 2, imagen 2 de 2
    • Remove the battery with an opening tool or fingernail.
  3. ZTE ZFive G LTE Volume and Power Button Replacement: paso 3, imagen 1 de 2 ZTE ZFive G LTE Volume and Power Button Replacement: paso 3, imagen 2 de 2
    • Unscrew all 16 screws from the mid-frame with a J000 screwdriver.
  4. ZTE ZFive G LTE Volume and Power Button Replacement: paso 4, imagen 1 de 2 ZTE ZFive G LTE Volume and Power Button Replacement: paso 4, imagen 2 de 2
    • Being careful with the device, gently pull up the device body tugging from the inside of the device.
    • Be sure to pull away from the device.
  5. ZTE ZFive G LTE Volume and Power Button Replacement: paso 5, imagen 1 de 2 ZTE ZFive G LTE Volume and Power Button Replacement: paso 5, imagen 2 de 2
    Herramienta utilizada en este paso:
    • Carefully use a pair of bent nose tweezers to pull out the button cover. I should come out easily.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 1
Todo El Tiempo: 346
