Saltar al contenido principal
Yamaha GA-10 Speaker Replacement
Joel H Murphey
Joel H Murphey y 3 otros contribuidores
Última actualización: March 31, 2025
20 - 35 minutos
Moderado
Fotos de acción
Necesita mejores imágenes
Error de marcado
Necesita más imágenes
Mejor introducción
Estudiante en Progreso
Introducción
Ir al paso 1
This guide provides step-by-step instructions to replace the speaker in the Yamaha GA-10 guitar amplifier. Issues such as distorted sound, intermittent audio, or complete loss of sound might be fixed by replacing the speaker. Make sure that your speaker is not plugged into any power source while attempting this replacement to prevent an electrical hazard.
Qué necesitas
Herramientas
  1. Yamaha GA-10 Speaker Replacement, Speaker: paso 1, imagen 1 de 3 Yamaha GA-10 Speaker Replacement, Speaker: paso 1, imagen 2 de 3 Yamaha GA-10 Speaker Replacement, Speaker: paso 1, imagen 3 de 3
    • Turn the amp around until you can see 2 screws on the back-bottom of the amp.
    • Using the Phillips #0 screwdriver, remove the two screws found at the back-bottom of the amp.
  2. Yamaha GA-10 Speaker Replacement: paso 2, imagen 1 de 2 Yamaha GA-10 Speaker Replacement: paso 2, imagen 2 de 2
    • Remove the plate found at the back-bottom that you removed the screws from.
    • The speaker should no longer be obstructed.
    • Remove the four screws on the corners of the speaker that are holding it in place.
  3. Yamaha GA-10 Speaker Replacement: paso 3, imagen 1 de 1
    • Remove the speaker from the amp in order to more clearly see the 2 wires connecting it.
  4. Yamaha GA-10 Speaker Replacement: paso 4, imagen 1 de 1
    • You may now gently pull the wires out of the speaker one at a time, until both are removed.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 29
Todo El Tiempo: 563
