Saltar al contenido principal
Xelio P900A-BK Battery Replacement
Marcus Nelson
Marcus Nelson y 4 otros contribuidores
Última actualización: July 11, 2018
7 - 10 minutos
Difícil
Rebanar y Trocear
Introducción
Ir al paso 1
Use this guide to remove and replace a dead battery in the Xelio P900A-BK tablet.
Qué necesitas
Herramientas
Ver más…
  1. Xelio P900A-BK Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Using a #00 Phillips head screwdriver, remove the two 5.4mm bottom screws.
  2. Xelio P900A-BK Battery Replacement: paso 2, imagen 1 de 2 Xelio P900A-BK Battery Replacement: paso 2, imagen 2 de 2
    • Insert a plastic opening tool between the screen and the rear case and gently work your way around the tablet.
  3. Xelio P900A-BK Battery Replacement: paso 3, imagen 1 de 1
    • Using the plastic opening tool or your fingers, gently pry the pieces of the tablet apart. You will hear the plastic latches pop free.
  4. Xelio P900A-BK Battery Replacement: paso 4, imagen 1 de 3 Xelio P900A-BK Battery Replacement: paso 4, imagen 2 de 3 Xelio P900A-BK Battery Replacement: paso 4, imagen 3 de 3
  5. Xelio P900A-BK Battery Replacement: paso 5, imagen 1 de 2 Xelio P900A-BK Battery Replacement: paso 5, imagen 2 de 2
    • Carefully insert the flat end of a nylon spudger under the battery, and pry the battery up and away from the tablet casing.
    • A small amount of heat may be required to safely remove the battery from the adhesive underneath. Use an iOpener or heat gun to soften the adhesive.
    • Do not bend or puncture the battery.
    • Place the new battery in the same place as the old one, making sure it is oriented the same way as the old one was.
Conclusión
2 personas más completaron esta guía.
Marcus Nelson
Miembro Desde 03/26/15
307 Reputación
3 Guías creadas
Equipo
Un comentario
I am attempting to fix one of these for a friend, but I can't seem to get it open! Does it require a significant amount of force? I am afraid I will break it...
skatermonkey06 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 4
Todo El Tiempo: 370
