Saltar al contenido principal
Xbox One Stereo Headset Microphone Replacement
Trevor Steele
Trevor Steele y 2 otros contribuidores
Última actualización: June 18, 2015
15 - 30 minutos
Difícil
Guía de Estudiante Destacada
Introducción
Ir al paso 1
This guide has only a few simple steps to get to the microphone. However, soldering is required to fully detach the microphone from the headset and install a replacement. Please refer to the soldering technique guide for instructions on soldering and desoldering.
Qué necesitas
Herramientas
Ver más…
  1. Xbox One Stereo Headset Microphone Replacement, Microphone: paso 1, imagen 1 de 3 Xbox One Stereo Headset Microphone Replacement, Microphone: paso 1, imagen 2 de 3 Xbox One Stereo Headset Microphone Replacement, Microphone: paso 1, imagen 3 de 3
    • Use the flat end of a spudger to pry out the rubber stopper at the base of the boom.
  2. Xbox One Stereo Headset Microphone Replacement: paso 2, imagen 1 de 1
    • Remove the single 6 mm flathead #2.0 screw exposed after removing the rubber stopper.
  3. Xbox One Stereo Headset Microphone Replacement: paso 3, imagen 1 de 1
    • Lift the joint of the boom up and over its pivot point to separate the microphone from the headset.
  4. Xbox One Stereo Headset Microphone Replacement: paso 4, imagen 1 de 3 Xbox One Stereo Headset Microphone Replacement: paso 4, imagen 2 de 3 Xbox One Stereo Headset Microphone Replacement: paso 4, imagen 3 de 3
    • Using the flat end of the metal spudger, pry the back plate off the boom.
    • The back plate is glued to the boom and must be removed gently.
    • When re-installing, apply a few drops of super glue to hold it in place.
  5. Xbox One Stereo Headset Microphone Replacement: paso 5, imagen 1 de 1
    • Pull the back plate off the boom.
  6. Xbox One Stereo Headset Microphone Replacement: paso 6, imagen 1 de 1
    • Using the flat end of the plastic spudger, gently pry the microphone out of its casing.
    • Desolder the two wires from the back of the microphone. For instructions on how to solder and desolder, please see the soldering technique guide.
    • The white wire connects to the positive node, which is indicated with a "+" on the microphone.
Conclusión
4 personas más completaron esta guía.
Trevor Steele
Miembro Desde 02/01/15
233 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 17-37, Amido Winter 2015 Miembro de Cal Poly, Team 17-37, Amido Winter 2015
CPSU-AMIDO-W15S17G37
Miembros de 4
5 Guías creadas
9Guía Comentarios
Is a replacement microphone available from iFixit?
Scott Minton - Contestar
What do you replace the mic with?
Its Me - Contestar
They have the microphone for sale
daniel david guerrerogarcia - Contestar
Would it presumably be just as easy to replace the microphone speaker with one from another headset, granted it fits ?
harumscxarum - Contestar
Any mod to make the cable removable?
kikis.andcream - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 6
Ultimos 30 días: 50
Todo El Tiempo: 24,163
