Saltar al contenido principal
Wexford CT-166TF Plastic Casing Replacement
Qué necesitas
  1. Wexford CT-166TF Plastic Casing  Replacement, Settings Knob: paso 1, imagen 1 de 1
    • Locate the knob at the top of the fan.
  2. Wexford CT-166TF Plastic Casing  Replacement: paso 2, imagen 1 de 1
    • Remove the knob by gripping it and pulling straight up. Use a spudger if it is difficult to grip.
    • When reassembling, be sure to align the bottom of the new knob and the turning mechanism in the fan before pushing down.
  3. Wexford CT-166TF Plastic Casing  Replacement, Plastic Casing: paso 3, imagen 1 de 1
    • Using the plastic opening tool, turn the device over and remove the black plastic covers over the four screw holes.
  4. Wexford CT-166TF Plastic Casing  Replacement: paso 4, imagen 1 de 2 Wexford CT-166TF Plastic Casing  Replacement: paso 4, imagen 2 de 2
    • Remove the four screws underneath the plastic covers.
  5. Wexford CT-166TF Plastic Casing  Replacement: paso 5, imagen 1 de 2 Wexford CT-166TF Plastic Casing  Replacement: paso 5, imagen 2 de 2
    • Remove 5 smaller screws visible through small holes between the base and the casing.
  6. Wexford CT-166TF Plastic Casing  Replacement: paso 6, imagen 1 de 2 Wexford CT-166TF Plastic Casing  Replacement: paso 6, imagen 2 de 2
    • Remove four screws on the back, two near the top and two near the bottom.
  7. Wexford CT-166TF Plastic Casing  Replacement: paso 7, imagen 1 de 1
    • Pull off the back casing.
  8. Wexford CT-166TF Plastic Casing  Replacement: paso 8, imagen 1 de 2 Wexford CT-166TF Plastic Casing  Replacement: paso 8, imagen 2 de 2
    • Remove the 2 screws that attach the front part of the casing to the motor.
  9. Wexford CT-166TF Plastic Casing  Replacement: paso 9, imagen 1 de 2 Wexford CT-166TF Plastic Casing  Replacement: paso 9, imagen 2 de 2
    • Remove the two middle screws attaching the black plastic cover to the front .
  10. Wexford CT-166TF Plastic Casing  Replacement: paso 10, imagen 1 de 1
    • Remove the two screws attached to the white bar near the red light on the top of the front casing.
  11. Wexford CT-166TF Plastic Casing  Replacement: paso 11, imagen 1 de 1
    • Remove the two screws keeping the button attached to the top of the casing.
Conclusión
Una persona más ha completado esta guía.
Equipo
UW Tacoma, Team S3-G4, Liner Spring 2017 Miembro de UW Tacoma, Team S3-G4, Liner Spring 2017
UWT-LINER-S17S3G4
4 Miembros
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 19
Todo El Tiempo: 367
