Ulco Integrus PSV Battery Replacement
Introducción
Ir al paso 1This guide will show you how to access and replace the battery of the ventilator.
Preparation to service:
- Make sure anaesthetic machine is OFF
- Disconnect the machine from power supply
- Gain access to ventilator housing from guide below
For more information on replacing the battery, please refer to page 29 in the service manual.
Qué necesitas
Before disassembly, make sure the front wheel breaks are on.
Remove the rear plastic cover by turning the single hex key retaining clip to free the cover.
Remove the main cover plate from the ventilator enclosure by removing all screws.
