Saltar al contenido principal
Trek FX2 Fitness Bike Saddle Replacement
David Fong
David Fong y 3 otros contribuidores
Última actualización: December 23, 2024
10 - 15 minutos
Fácil
Introducción
Ir al paso 1
This guide shows how to remove and replace a saddle on a bicycle. The steps include removing the current saddle, lubricating the bolts and rails, reinstalling the new saddle, and securing the saddle's connection to the frame.
The bike seat used in this guide is a Trek Fx2, a hybrid bike meant for fitness and commuting, although the instructions apply to many other bike saddles, whether they have two bolt or one bolt configurations. If you are unfamiliar with this process, we recommend taking some pictures of the different angles of your seat placement before starting so that you know what configuration to set it back to.
This process can be helpful when your bike saddle is damaged or if the seat is improperly set on the bike. With such replacement, you can continue to use your bike for its intended purpose.
  1. Trek FX2 Fitness Bike Saddle Replacement, Saddle: paso 1, imagen 1 de 3 Trek FX2 Fitness Bike Saddle Replacement, Saddle: paso 1, imagen 2 de 3 Trek FX2 Fitness Bike Saddle Replacement, Saddle: paso 1, imagen 3 de 3
    • Locate the bolt under the saddle.
    • Use a 5mm Allen Wrench to loosen and remove the M8x30 mm bolt.
    • Remove the saddle from under the plate.
  2. Trek FX2 Fitness Bike Saddle Replacement: paso 2, imagen 1 de 2 Trek FX2 Fitness Bike Saddle Replacement: paso 2, imagen 2 de 2
    • Use a towel covered in isopropyl rubbing alcohol to clean any dirt from the bolts and plate.
  3. Trek FX2 Fitness Bike Saddle Replacement: paso 3, imagen 1 de 2 Trek FX2 Fitness Bike Saddle Replacement: paso 3, imagen 2 de 2
    • Apply Finish Line Premium Grease to the bolt.
    • Work the grease around the threads.
  4. Trek FX2 Fitness Bike Saddle Replacement: paso 4, imagen 1 de 3 Trek FX2 Fitness Bike Saddle Replacement: paso 4, imagen 2 de 3 Trek FX2 Fitness Bike Saddle Replacement: paso 4, imagen 3 de 3
    • Clean the replacement bicycle saddle with a towel and isopropyl alcohol.
  5. Trek FX2 Fitness Bike Saddle Replacement: paso 5, imagen 1 de 2 Trek FX2 Fitness Bike Saddle Replacement: paso 5, imagen 2 de 2
    • Apply Finish Line Premium Grease to the rails of the bicycle saddle.
  6. Trek FX2 Fitness Bike Saddle Replacement: paso 6, imagen 1 de 3 Trek FX2 Fitness Bike Saddle Replacement: paso 6, imagen 2 de 3 Trek FX2 Fitness Bike Saddle Replacement: paso 6, imagen 3 de 3
    • Align the seat rails with the channels in the saddle plate.
    • Slide the rails into the channels of the saddle plate.
    • Adjust the seat position to your preference.
  7. Trek FX2 Fitness Bike Saddle Replacement: paso 7, imagen 1 de 3 Trek FX2 Fitness Bike Saddle Replacement: paso 7, imagen 2 de 3 Trek FX2 Fitness Bike Saddle Replacement: paso 7, imagen 3 de 3
    • Insert the bolts into the holes on the saddle plate.
    • Tighten the bolts by hand until they are snug.
    • Use an Allen wrench to evenly tighten the bolts.
  8. Trek FX2 Fitness Bike Saddle Replacement: paso 8, imagen 1 de 1
    • Sit on the seat to check its angle and stability.
Conclusión
Test out the bike seat, and adjust accordingly.
David Fong
Miembro Desde 11/05/24
157 Reputación
1 Guía escrita
Equipo
UC Davis, Team 4-6, Vidal-Chiesa Fall 2024 Miembro de UC Davis, Team 4-6, Vidal-Chiesa Fall 2024
UCD-VIDAL-CHIESA-F24S4G6
Miembros de 3
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 17
Todo El Tiempo: 89
