Toshiba Satellite P105-S6147 Motherboard Replacement
Introducción
Ir al paso 1This is a replacement guide for the Toshiba Satellite P105-S6147 Motherboard. This part houses some of the most important parts of the computer, including the central processing unit (CPU). Refer to this troubleshooting guide before replacing the motherboard. Replace this part if your computer continues to operate slowly after troubleshooting, or if the device is overheating while the fan is fully functional.
All the tools you will need in this guide can be found in the iFixit Pro Toolkit. We suggest you perform this replacement on a large, level workspace where you can avoid knocking small parts onto the floor. Label any small parts so you know where to put them when reassembling the laptop.
Consult the Toshiba Satellite P105-S6147 Device Page for further questions.
Qué necesitas
Herramientas
Ver más…
Begin by placing the laptop face down on a flat surface.
Slide the lock switch on the battery to the unlocked position.
Slide the release lever on the battery towards the lock switch. The battery should now rotate out of its dock in the laptop.
