Saltar al contenido principal
Toshiba Satellite P105-S6147 Cooling Fan Replacement
Benjamin Wilkinson
Benjamin Wilkinson y 6 otros contribuidores
Última actualización: May 7, 2024
25 - 30 minutos
Moderado
Introducción
Ir al paso 1
This is a replacement guide for the Toshiba Satellite P105-S6147 cooling fan. This part is responsible for preventing the device from overheating. Refer to this troubleshooting guide before replacing the cooling fan. Replace this part if the device continues to overheat after troubleshooting.
All the tools you will need in this guide can be found in the iFixit Pro Toolkit. We suggest you perform this replacement on a large, level workspace where you can avoid knocking small parts onto the floor. Label any small parts so you know where to put them when reassembling the laptop.
Consult the Toshiba Satellite P105-S6147 Device Page for further questions.
Qué necesitas
Herramientas
Ver más…
  1. Toshiba Satellite P105-S6147 Cooling Fan Replacement, Motherboard: paso 1, imagen 1 de 3 Toshiba Satellite P105-S6147 Cooling Fan Replacement, Motherboard: paso 1, imagen 2 de 3 Toshiba Satellite P105-S6147 Cooling Fan Replacement, Motherboard: paso 1, imagen 3 de 3
    • Begin by placing the laptop face down on a flat surface.
    • The battery is located in the bottom left hand corner of the device.
    • Slide the lock switch on the battery to the unlocked position.
    • Slide the release lever on the battery towards the lock switch. The battery should now rotate out of its dock in the laptop.
  2. Toshiba Satellite P105-S6147 Cooling Fan Replacement: paso 2, imagen 1 de 3 Toshiba Satellite P105-S6147 Cooling Fan Replacement: paso 2, imagen 2 de 3 Toshiba Satellite P105-S6147 Cooling Fan Replacement: paso 2, imagen 3 de 3
    Herramienta utilizada en este paso:
    • Remove the casing located next to the battery.
    • Using a #0 Phillips screwdriver, remove the two 4 mm screws.
    • Use the precision tweezers to disconnect the white and black wire from the device.
    • Remove the thin black wire from the device.
  3. Toshiba Satellite P105-S6147 Cooling Fan Replacement: paso 3, imagen 1 de 3 Toshiba Satellite P105-S6147 Cooling Fan Replacement: paso 3, imagen 2 de 3 Toshiba Satellite P105-S6147 Cooling Fan Replacement: paso 3, imagen 3 de 3
    • Open the remaining casings using a #0 Phillips screwdriver.
    • Remove all visible screws on the bottom of the laptop to complete this step.
  4. Toshiba Satellite P105-S6147 Cooling Fan Replacement: paso 4, imagen 1 de 3 Toshiba Satellite P105-S6147 Cooling Fan Replacement: paso 4, imagen 2 de 3 Toshiba Satellite P105-S6147 Cooling Fan Replacement: paso 4, imagen 3 de 3
    • Hold the back cover slightly open.
    • Use the precision tweezers to disconnect the two ribbon cables at the bottom of the laptop.
    • Open the small black clips to free the ribbon cables.
    • Remove the back cover.
  5. Toshiba Satellite P105-S6147 Cooling Fan Replacement: paso 5, imagen 1 de 3 Toshiba Satellite P105-S6147 Cooling Fan Replacement: paso 5, imagen 2 de 3 Toshiba Satellite P105-S6147 Cooling Fan Replacement: paso 5, imagen 3 de 3
    • Locate the white plug in the upper right hand corner of the laptop.
    • Use the iFixit opening tools to apply even, backwards pressure to each side of the plug until the plug is free from the motherboard.
  6. Toshiba Satellite P105-S6147 Cooling Fan Replacement: paso 6, imagen 1 de 2 Toshiba Satellite P105-S6147 Cooling Fan Replacement: paso 6, imagen 2 de 2
    • Locate the ribbon cable on the bottom of the laptop.
    • Open the small black clip that is holding the ribbon cable.
    • Gently remove the ribbon cable with the precision tweezers.
  7. Toshiba Satellite P105-S6147 Cooling Fan Replacement: paso 7, imagen 1 de 3 Toshiba Satellite P105-S6147 Cooling Fan Replacement: paso 7, imagen 2 de 3 Toshiba Satellite P105-S6147 Cooling Fan Replacement: paso 7, imagen 3 de 3
    • Locate the white plug next to the ribbon cable that was removed in the previous step.
    • Gently unplug the plug with your hand or the blue iFixit opening tools.
  8. Toshiba Satellite P105-S6147 Cooling Fan Replacement: paso 8, imagen 1 de 1
    • Remove the motherboard from the laptop casing.
  9. Toshiba Satellite P105-S6147 Cooling Fan Replacement, Cooling Fan: paso 9, imagen 1 de 3 Toshiba Satellite P105-S6147 Cooling Fan Replacement, Cooling Fan: paso 9, imagen 2 de 3 Toshiba Satellite P105-S6147 Cooling Fan Replacement, Cooling Fan: paso 9, imagen 3 de 3
    • Use the precision tweezers to remove the metal cover off the top of the cooling fan. It should "pop" off with little effort.
    • Flip over the motherboard.
    • The cooling fan is now located in the upper left-hand corner of the motherboard.
  10. Toshiba Satellite P105-S6147 Cooling Fan Replacement: paso 10, imagen 1 de 2 Toshiba Satellite P105-S6147 Cooling Fan Replacement: paso 10, imagen 2 de 2
    • Remove the two 5 mm screws located at the bottom right of the cooling fan.
    • The cooling fan housing is now free from the motherboard.
  11. Toshiba Satellite P105-S6147 Cooling Fan Replacement: paso 11, imagen 1 de 2 Toshiba Satellite P105-S6147 Cooling Fan Replacement: paso 11, imagen 2 de 2
    • Locate the white plug connecting the cooling fan to the motherboard.
    • Gently pull on the plug to disconnect the cooling fan from the motherboard.
    • Remove the cooling fan from the motherboard.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 6
Ultimos 30 días: 22
Todo El Tiempo: 279
