Saltar al contenido principal
Toshiba Satellite C55-C5240 Screen Replacement
Angela Rodriguez
Angela Rodriguez y 3 otros contribuidores
Última actualización: May 7, 2024
10 - 15 minutos
Moderado
Introducción
Ir al paso 1
When the screen is cracked or just does not work, it will need to be replaced. This is the guide you need to help you do that.
Qué necesitas
Herramientas
Ver más…
  1. Toshiba Satellite C55-C5240 Screen Replacement, Battery: paso 1, imagen 1 de 3 Toshiba Satellite C55-C5240 Screen Replacement, Battery: paso 1, imagen 2 de 3 Toshiba Satellite C55-C5240 Screen Replacement, Battery: paso 1, imagen 3 de 3
    • Make sure you turn off the laptop before starting.
    • Remove the two 6.5mm PH1 Phillips screws securing the battery.
  2. Toshiba Satellite C55-C5240 Screen Replacement: paso 2, imagen 1 de 3 Toshiba Satellite C55-C5240 Screen Replacement: paso 2, imagen 2 de 3 Toshiba Satellite C55-C5240 Screen Replacement: paso 2, imagen 3 de 3
    • Pull the battery out, keeping it flat and parallel to the laptop so that it slides out easily.
  3. Toshiba Satellite C55-C5240 Screen Replacement, Back cover: paso 3, imagen 1 de 2 Toshiba Satellite C55-C5240 Screen Replacement, Back cover: paso 3, imagen 2 de 2
    • Unscrew the ten 6.5mm PH1 Phillips head screws that hold down the back cover.
  4. Toshiba Satellite C55-C5240 Screen Replacement: paso 4, imagen 1 de 3 Toshiba Satellite C55-C5240 Screen Replacement: paso 4, imagen 2 de 3 Toshiba Satellite C55-C5240 Screen Replacement: paso 4, imagen 3 de 3
    • Using the plastic opening tools, open the back cover and remove it from the laptop.
    • It is recommended that you start from a corner and run the tool along the edge of the cover.
    • Be careful not to bend or crack the cover.
  5. Toshiba Satellite C55-C5240 Screen Replacement, Screen: paso 5, imagen 1 de 3 Toshiba Satellite C55-C5240 Screen Replacement, Screen: paso 5, imagen 2 de 3 Toshiba Satellite C55-C5240 Screen Replacement, Screen: paso 5, imagen 3 de 3
    • Carefully disconnect these three cables.
  6. Toshiba Satellite C55-C5240 Screen Replacement: paso 6, imagen 1 de 1
    • Open the laptop at a right angle to make the later removal much easier.
  7. Toshiba Satellite C55-C5240 Screen Replacement: paso 7, imagen 1 de 3 Toshiba Satellite C55-C5240 Screen Replacement: paso 7, imagen 2 de 3 Toshiba Satellite C55-C5240 Screen Replacement: paso 7, imagen 3 de 3
    • Unscrew the four PH1 Phillips head screws on the hinges.
  8. Toshiba Satellite C55-C5240 Screen Replacement: paso 8, imagen 1 de 2 Toshiba Satellite C55-C5240 Screen Replacement: paso 8, imagen 2 de 2
    • Separate the screen from the rest of the laptop.
    • Make sure the cables do not catch on the bottom piece.
  9. Toshiba Satellite C55-C5240 Screen Replacement: paso 9, imagen 1 de 3 Toshiba Satellite C55-C5240 Screen Replacement: paso 9, imagen 2 de 3 Toshiba Satellite C55-C5240 Screen Replacement: paso 9, imagen 3 de 3
    Herramienta utilizada en este paso:
    • Using a pair of tweezers, remove the two stickers on the bottom of the screen.
    • Unscrew the two screws underneath.
  10. Toshiba Satellite C55-C5240 Screen Replacement: paso 10, imagen 1 de 3 Toshiba Satellite C55-C5240 Screen Replacement: paso 10, imagen 2 de 3 Toshiba Satellite C55-C5240 Screen Replacement: paso 10, imagen 3 de 3
    • Stick the plastic opening tool underneath the screen bezel and run it along the edge of the screen.
    • Loosen each hinge separately, it would be more difficult otherwise.
  11. Toshiba Satellite C55-C5240 Screen Replacement: paso 11, imagen 1 de 3 Toshiba Satellite C55-C5240 Screen Replacement: paso 11, imagen 2 de 3 Toshiba Satellite C55-C5240 Screen Replacement: paso 11, imagen 3 de 3
    • Unscrew the four inner screws around the screen.
    • Leave the two outer screws on the top alone.
  12. Toshiba Satellite C55-C5240 Screen Replacement: paso 12, imagen 1 de 3 Toshiba Satellite C55-C5240 Screen Replacement: paso 12, imagen 2 de 3 Toshiba Satellite C55-C5240 Screen Replacement: paso 12, imagen 3 de 3
    • Mind the cable on the bottom of the screen.
    • Simply lift the screen out.
Conclusión
4 personas más completaron esta guía.
Equipo
USF Tampa, Team S1-G5, Nance Spring 2017 Miembro de USF Tampa, Team S1-G5, Nance Spring 2017
USFT-NANCE-S17S1G5
3 Miembros
18 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 19
Todo El Tiempo: 2,582
