Saltar al contenido principal
Toshiba Satellite A215-S7425 RAM Replacement
Marianne
Marianne y 6 otros contribuidores
Última actualización: March 7, 2024
5 - 10 minutos
Fácil
Mejor introducción
Qué necesitas
Herramientas
  1. Toshiba Satellite A215-S7425 RAM Replacement, Battery: paso 1, imagen 1 de 1
    • Turn off the computer.
    • Disconnect the charging cable from computer.
    • Failure to unplug the cable could result in electric shock.
    • Flip the computer upside down.
  2. Toshiba Satellite A215-S7425 RAM Replacement: paso 2, imagen 1 de 1
    • Slide latches labeled #1 and #2, located outside the battery cover, away from each other.
    • Latch #1 will click over and stay while latch #2 will have to be held for battery to release.
  3. Toshiba Satellite A215-S7425 RAM Replacement: paso 3, imagen 1 de 1
    • Gently lift and pull the battery out of the device.
  4. Toshiba Satellite A215-S7425 RAM Replacement, RAM: paso 4, imagen 1 de 1
    • Locate the RAM vented plastic cover in the center of the device.
  5. Toshiba Satellite A215-S7425 RAM Replacement: paso 5, imagen 1 de 2 Toshiba Satellite A215-S7425 RAM Replacement: paso 5, imagen 2 de 2
    • Loosen 1 Phillips 4.2 mm size captive screw and lift cover off device to expose 2 RAM sticks.
  6. Toshiba Satellite A215-S7425 RAM Replacement: paso 6, imagen 1 de 3 Toshiba Satellite A215-S7425 RAM Replacement: paso 6, imagen 2 de 3 Toshiba Satellite A215-S7425 RAM Replacement: paso 6, imagen 3 de 3
    Herramienta utilizada en este paso:
    Anti-Static Wrist Strap
    $7.95
    • Locate 2 metal pinchers on either side of the 1st RAM stick.
    • Use a finger from each hand to push the 2 pinchers simultaneously away from the stick of RAM and towards the exterior of the case.
    • The RAM stick will automatically rise up. Gently pull out the RAM stick with one hand.
    • The use of a anti-static wrist strap while working with the RAM is advise to prevent electrostatic discharge(ESD) from damaging the RAM.
  7. Toshiba Satellite A215-S7425 RAM Replacement: paso 7, imagen 1 de 3 Toshiba Satellite A215-S7425 RAM Replacement: paso 7, imagen 2 de 3 Toshiba Satellite A215-S7425 RAM Replacement: paso 7, imagen 3 de 3
    • To remove the 2nd RAM stick, repeat previous steps.
    • You will be unable to remove 2nd RAM stick if the first one is not removed first.
Conclusión
Marianne
Miembro Desde 09/08/14
647 Reputación
6 Guías creadas
Equipo
Pasco Hernando, Team 5-2, Prince Fall 2014 Miembro de Pasco Hernando, Team 5-2, Prince Fall 2014
PHSC-PRINCE-F14S5G2
Miembros de 10
18 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 30
Todo El Tiempo: 328
