Saltar al contenido principal
Toshiba Satellite A105-S4284 Casing Replacement
Josh
Josh y 2 otros contribuidores
Última actualización: July 16, 2014
15 - 20 minutos
Moderado
Mejor introducción
Qué necesitas
Herramientas
  1. Toshiba Satellite A105-S4284 Casing Replacement, Keyboard: paso 1, imagen 1 de 1
    • Flip the laptop over so it is rightside up, and open the laptop all the way so that the screen is horizontal.
  2. Toshiba Satellite A105-S4284 Casing Replacement: paso 2, imagen 1 de 3 Toshiba Satellite A105-S4284 Casing Replacement: paso 2, imagen 2 de 3 Toshiba Satellite A105-S4284 Casing Replacement: paso 2, imagen 3 de 3
    • Using the plastic opening tool, pry off the panel above the keyboard, starting near the right front speaker.
    • Use the plastic opening tool to pop off tabs along the length of this panel.
    • This may feel like you're about to break something, but as long as you work your way down the panel and don't yank it out, the laptop will be fine.
  3. Toshiba Satellite A105-S4284 Casing Replacement: paso 3, imagen 1 de 2 Toshiba Satellite A105-S4284 Casing Replacement: paso 3, imagen 2 de 2
    • Unscrew the two 4.5 mm screws holding the keyboard on with the Phillips #1 screwdriver.
  4. Toshiba Satellite A105-S4284 Casing Replacement: paso 4, imagen 1 de 3 Toshiba Satellite A105-S4284 Casing Replacement: paso 4, imagen 2 de 3 Toshiba Satellite A105-S4284 Casing Replacement: paso 4, imagen 3 de 3
    • Lift the keyboard gently from the side closest the screen.
    • Pull out the ribbon connecting the keyboard to the laptop.
  5. Toshiba Satellite A105-S4284 Casing Replacement, Casing: paso 5, imagen 1 de 3 Toshiba Satellite A105-S4284 Casing Replacement, Casing: paso 5, imagen 2 de 3 Toshiba Satellite A105-S4284 Casing Replacement, Casing: paso 5, imagen 3 de 3
    • Disconnect wire attaching LCD to motherboard
    • Using the Phillips screwdriver remove the two 4.0mm screws from each hinge above speakers
    • Partially close the lid and remove the last two 4.0mm screws from the back of the laptop.
  6. Toshiba Satellite A105-S4284 Casing Replacement: paso 6, imagen 1 de 2 Toshiba Satellite A105-S4284 Casing Replacement: paso 6, imagen 2 de 2
    • Remove the seventeen 4.5mm phillips screws on the bottom of the laptop.
    • Using the pry tool separate the two halves of the laptop base.
    • Use caution when separating the laptop halves as they are still connected by two ribbon cables.
  7. Toshiba Satellite A105-S4284 Casing Replacement: paso 7, imagen 1 de 2 Toshiba Satellite A105-S4284 Casing Replacement: paso 7, imagen 2 de 2
    • Lift the top half of the case enough to get your hand beneath it, and then remove the two ribbon cables that connect it to the motherboard.
Conclusión
2 personas más completaron esta guía.
Josh
Miembro Desde 03/12/14
685 Reputación
5 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 943
