Saltar al contenido principal
Toshiba Satellite A105-S4011 RAM Replacement
Lucas Salisbury
Lucas Salisbury y 9 otros contribuidores
Última actualización: January 21, 2025
5 minuto
Fácil
Introducción
Ir al paso 1
This guide will show you how to remove the current RAM module from this laptop and how to re-install a RAM module. Accessing the RAM in this computer is straightforward and requires minimal minimal dis-assembly.
Qué necesitas
Partes
Herramientas
Ver más…
iFixit gana una comisión si finalizas una compra usando estos enlaces.
  1. Toshiba Satellite A105-S4011 RAM Replacement, Battery: paso 1, imagen 1 de 2 Toshiba Satellite A105-S4011 RAM Replacement, Battery: paso 1, imagen 2 de 2
    • Turn the laptop over and locate the lock and battery release switches. Unlock the battery by changing the switch on the right from locked to unlocked by sliding the switch outward.
  2. Toshiba Satellite A105-S4011 RAM Replacement: paso 2, imagen 1 de 2 Toshiba Satellite A105-S4011 RAM Replacement: paso 2, imagen 2 de 2
    • Hold the release switch and pull out the battery towards you.
  3. Toshiba Satellite A105-S4011 RAM Replacement, RAM: paso 3, imagen 1 de 1
    • Locate the screw that is holding the back cover in place and, unscrew it using the #1 Phillips Screwdriver.
    • This screw cannot be taken out, it is a "captive" screw.
  4. Toshiba Satellite A105-S4011 RAM Replacement: paso 4, imagen 1 de 1
    • Using a plastic opening tool, pop off the back cover. Your going to insert the tool into the small slit located on the back cover piece.
    • Be careful when prying the back cover off because you may damage the cover or crack the plastic.
  5. Toshiba Satellite A105-S4011 RAM Replacement: paso 5, imagen 1 de 2 Toshiba Satellite A105-S4011 RAM Replacement: paso 5, imagen 2 de 2
    • Locate the RAM (green module pictured here), and the two prongs on each side of the module. Press the two prongs outwardly, and pull out the RAM module.
    • Grounding yourself may be a good idea before actually touching the RAM module. This entails touching a conductive metal in order to remove any excess static energy in your body.
Conclusión
Una persona más ha completado esta guía.
Equipo
Cal Poly, Team 4-14, Maness Spring 2013 Miembro de Cal Poly, Team 4-14, Maness Spring 2013
CPSU-MANESS-S13S4G14
4 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 11
Ultimos 30 días: 23
Todo El Tiempo: 1,314
