Saltar al contenido principal
Sony Xperia Sola Motherboard Replacement
Cary Drew
Cary Drew y 13 otros contribuidores
Última actualización: January 20, 2025
30 - 50 minutos
Moderado
Policía gramatical
Texto confuso
Necesita mejores imágenes
Rebanar y Trocear
Mejor introducción
Introducción
Ir al paso 1
This guide will assist you in taking apart the phone to remove the circuit board as this is a required step in almost all of the part replacements for this camera.
Qué necesitas
Herramientas
Ver más…
  1. Sony Xperia Sola Motherboard Replacement, Lay the phone as shown.: paso 1, imagen 1 de 2 Sony Xperia Sola Motherboard Replacement, Lay the phone as shown.: paso 1, imagen 2 de 2
    • Place phone down with screen side down and camera side facing up as shown.
    • Push on cover away from you. You should hear a snap or pop. This will let you view the battery and sim/sd card slots. Then lift the cover off.
  2. Sony Xperia Sola Motherboard Replacement, Remove the screws.: paso 2, imagen 1 de 3 Sony Xperia Sola Motherboard Replacement, Remove the screws.: paso 2, imagen 2 de 3 Sony Xperia Sola Motherboard Replacement, Remove the screws.: paso 2, imagen 3 de 3
    • Locate and remove the five (5) screws on the phone, using a screwdriver. The screws are at the top and the bottom of the phone as shown.
  3. Sony Xperia Sola Motherboard Replacement, Remove bottom white cover.: paso 3, imagen 1 de 2 Sony Xperia Sola Motherboard Replacement, Remove bottom white cover.: paso 3, imagen 2 de 2
    • Pry off the bottom white cover by using the opening tool as a lever.
  4. Sony Xperia Sola Motherboard Replacement, Remove more screws.: paso 4, imagen 1 de 2 Sony Xperia Sola Motherboard Replacement, Remove more screws.: paso 4, imagen 2 de 2
    • Locate and remove the 2 additional screws, using the Torx screwdriver, that are revealed. These are marked as shown.
  5. Sony Xperia Sola Motherboard Replacement, Remove black cover.: paso 5, imagen 1 de 2 Sony Xperia Sola Motherboard Replacement, Remove black cover.: paso 5, imagen 2 de 2
    • Locate the black cover on the bottom left of phone. Use an opening tool to pry up and remove the black cover.
  6. Sony Xperia Sola Motherboard Replacement, Disconnect the battery's circuit.: paso 6, imagen 1 de 1
    Herramienta utilizada en este paso:
    • Disconnect the circuit by lifting the connector straight up as shown using the tweezers.
  7. Sony Xperia Sola Motherboard Replacement, Remove the phone's inner back cover.: paso 7, imagen 1 de 3 Sony Xperia Sola Motherboard Replacement, Remove the phone's inner back cover.: paso 7, imagen 2 de 3 Sony Xperia Sola Motherboard Replacement, Remove the phone's inner back cover.: paso 7, imagen 3 de 3
    • Turn the phone onto its side, insert plastic opening tool into seam, and gently remove cover. You can also slide the spudger in from the top.
    • Once the cover is loose, lift it off the phone. The side buttons may feel a bit sticky, but this is normal.
  8. Sony Xperia Sola Motherboard Replacement, Remove the additional power circuit.: paso 8, imagen 1 de 1
    • Locate the additional circuit at the bottom left. Using the tweezers, remove it gently by pulling up.
  9. Sony Xperia Sola Motherboard Replacement, Repeat for the circuit on the top end of the battery.: paso 9, imagen 1 de 2 Sony Xperia Sola Motherboard Replacement, Repeat for the circuit on the top end of the battery.: paso 9, imagen 2 de 2
    • Use the tweezers to lift up on the circuit located at the top left.
  10. Sony Xperia Sola Motherboard Replacement, Remove the motherboard.: paso 10, imagen 1 de 1
    • Use the spudger and slide it under the top left of the board then lift the board straight up. The board should come up very easily.
Conclusión
5 personas más completaron esta guía.
Cary Drew
Miembro Desde 09/25/14
866 Reputación
5 Guías creadas
Equipo
USF Tampa, Team 1-1, Brown Fall 2014 Miembro de USF Tampa, Team 1-1, Brown Fall 2014
USFT-BROWN-F14S1G1
4 Miembros
5 Guías creadas
2 comentarios
Some of these pictures are too blurry.
Dan Brown - Contestar
You need written instructions for each step.
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 7
Ultimos 30 días: 9
Todo El Tiempo: 1,107
