Saltar al contenido principal
Sony UBP-UX80 Wi-Fi Card Replacement
Nate Picard
Nate Picard y 3 otros contribuidores
Última actualización: August 28, 2023
Sin estimación
Moderado
Introducción
Ir al paso 1
This part connects the device to the internet so that it can receive software updates from Sony and so that the owner can access their desired streaming services and use the Blu ray player as multi-media device,
Please follow the top cover and front panel removal as this card is located right under the both those panels in the center of the device.
Qué necesitas
Herramientas
Ver más…
  1. Sony UBP-UX80 Wi-Fi Card Replacement, Top Cover: paso 1, imagen 1 de 3 Sony UBP-UX80 Wi-Fi Card Replacement, Top Cover: paso 1, imagen 2 de 3 Sony UBP-UX80 Wi-Fi Card Replacement, Top Cover: paso 1, imagen 3 de 3
    • Use a Phillips #2 screwdriver to remove the two 10.5 mm screws that secure the two side panels onto the back of the player.
    • Slide both covers back about a 1/2 inch, then pull them away from the case.
  2. Sony UBP-UX80 Wi-Fi Card Replacement: paso 2, imagen 1 de 3 Sony UBP-UX80 Wi-Fi Card Replacement: paso 2, imagen 2 de 3 Sony UBP-UX80 Wi-Fi Card Replacement: paso 2, imagen 3 de 3
    • Use a Phillips #2 screwdriver to remove the two 10.5 mm screws on the side of the case, each connecting to a tab on the cover.
    • Similar to the previous step, it is identical cases on both sides of the device.
    • Use a Phillips #2 screwdriver to remove the two 10.5 mm screws (one next to the Wi-Fi logo and one next to the Blu-ray logo).
  3. Sony UBP-UX80 Wi-Fi Card Replacement: paso 3, imagen 1 de 2 Sony UBP-UX80 Wi-Fi Card Replacement: paso 3, imagen 2 de 2
    • Press in the tabs found on the front-sides of the case (connected to the front panel).
    • Slide the top cover forward.
    • Lift off the case.
  4. Sony UBP-UX80 Wi-Fi Card Replacement: paso 4, imagen 1 de 3 Sony UBP-UX80 Wi-Fi Card Replacement: paso 4, imagen 2 de 3 Sony UBP-UX80 Wi-Fi Card Replacement: paso 4, imagen 3 de 3
    • Find the eleven 10.5 mm silver screws and two 6 mm black screws on the perimeter of the silver cover plate.
    • Remove the silver screws using a Phillips #2 screwdriver and the black ones using a Phillips #1 screwdriver.
    • Life the back of the cover up and off of the chasis.
  5. Sony UBP-UX80 Wi-Fi Card Replacement, Front Cover: paso 5, imagen 1 de 3 Sony UBP-UX80 Wi-Fi Card Replacement, Front Cover: paso 5, imagen 2 de 3 Sony UBP-UX80 Wi-Fi Card Replacement, Front Cover: paso 5, imagen 3 de 3
    • Toward the panel there is a ribbon cable with 4 small black pieces of tape holding it down
    • Pull directly up on the ribbon cable to disconnect it from the motherboard
    • Gently pull the cable back away from the motherboard pulling the tape off with it
  6. Sony UBP-UX80 Wi-Fi Card Replacement: paso 6, imagen 1 de 1
    • Once all pieces of tape have been pulled up, the ribbon cable should look like this.
  7. Sony UBP-UX80 Wi-Fi Card Replacement: paso 7, imagen 1 de 2 Sony UBP-UX80 Wi-Fi Card Replacement: paso 7, imagen 2 de 2
    • There are screws on every side of the front panel holding it in. Use a #2 Phillips head screwdriver to remove the nine screws.
    • Unscrew the three 10.5 mm long ph #2 screws on the top.
    • Unscrew the four 10.5 mm long ph #2 screws on the bottom.
  8. Sony UBP-UX80 Wi-Fi Card Replacement: paso 8, imagen 1 de 2 Sony UBP-UX80 Wi-Fi Card Replacement: paso 8, imagen 2 de 2
    • Use a Phillips #2 screwdriver to remove the 10.5 mm screws, one on each side of the device.
  9. Sony UBP-UX80 Wi-Fi Card Replacement: paso 9, imagen 1 de 3 Sony UBP-UX80 Wi-Fi Card Replacement: paso 9, imagen 2 de 3 Sony UBP-UX80 Wi-Fi Card Replacement: paso 9, imagen 3 de 3
    • Lift tab on the left side of the device
    • Work your way right, lifting the next tabs. One on the bottom and one the Top
    • Continue working the tabs on the top and bottom, keeping them from snapping back in place.
  10. Sony UBP-UX80 Wi-Fi Card Replacement: paso 10, imagen 1 de 1
    • Once all tabs are disconnected, pull the front panel forward to fully disconnect it
  11. Sony UBP-UX80 Wi-Fi Card Replacement, Wi-Fi Card: paso 11, imagen 1 de 2 Sony UBP-UX80 Wi-Fi Card Replacement, Wi-Fi Card: paso 11, imagen 2 de 2
    • Disconnect the power connection by pulling it straight back and out of the card.
  12. Sony UBP-UX80 Wi-Fi Card Replacement: paso 12, imagen 1 de 2 Sony UBP-UX80 Wi-Fi Card Replacement: paso 12, imagen 2 de 2
    • Remove the gold-colored connection, remove the tape, and pull it off using the wire. Be gentle because the wire is very small as is the connection.
  13. Sony UBP-UX80 Wi-Fi Card Replacement: paso 13, imagen 1 de 1
    • Use a Phillips #2 screwdriver to remove the two 4.6 mm screws that secure the card.
  14. Sony UBP-UX80 Wi-Fi Card Replacement: paso 14, imagen 1 de 1
    • Lift up slightly on the back of the card, and pull out (toward the back of the chassis).
Conclusión
Nate Picard
Miembro Desde 03/13/23
349 Reputación
3 Guías creadas
Equipo
UMass Dartmouth, Team 2-5, Petersen Spring 2023 Miembro de UMass Dartmouth, Team 2-5, Petersen Spring 2023
UMASSD-PETERSEN-S23S2G5
Miembros de 4
8 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 9
Ultimos 30 días: 14
Todo El Tiempo: 109
