Saltar al contenido principal
Sony Cyber-shot DSC-P52 Outer Case Replacement
Trevor
Trevor y 6 otros contribuidores
Última actualización: December 3, 2020
2 - 10 minutos
Moderado
Introducción
Ir al paso 1
This guide is used for taking apart the case to fix many of the issues of the Sony Cybershot DSC-P52.
Qué necesitas
Herramientas
  1. Sony Cyber-shot DSC-P52 Outer Case Replacement, Outer Case: paso 1, imagen 1 de 1
    • Open the battery compartment and remove the batteries.
    • Remove all of the visible screws on the outside of the case.
    • There should be three of them that are all easily located.
  2. Sony Cyber-shot DSC-P52 Outer Case Replacement: paso 2, imagen 1 de 1
    • Open the memory card compartment.
    • Remove the screw next to the memory card slot.
  3. Sony Cyber-shot DSC-P52 Outer Case Replacement: paso 3, imagen 1 de 1
    • Pull apart the front and back cover pieces carefully.
    • The front cover should come completely free with little effort.
    • The back cover will still be attached to the circuit board.
  4. Sony Cyber-shot DSC-P52 Outer Case Replacement: paso 4, imagen 1 de 1
    • Simultaneously unclip all of the clips holding in the circuitry. Remove the back case.
    • The circuitry will still be connected to the back case by ribbon cables.
  5. Sony Cyber-shot DSC-P52 Outer Case Replacement: paso 5, imagen 1 de 1
    • Open the case as shown.
  6. Sony Cyber-shot DSC-P52 Outer Case Replacement: paso 6, imagen 1 de 1
    • Unclip the clip holding the ribbon cable in.
    • Other ribbon cables might not have a clips.
  7. Sony Cyber-shot DSC-P52 Outer Case Replacement: paso 7, imagen 1 de 1
    • Pull the ribbon cable out.
Conclusión
Una persona más ha completado esta guía.
Trevor
Miembro Desde 01/20/11
319 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 3-43, Regan Winter 2011 Miembro de Cal Poly, Team 3-43, Regan Winter 2011
CPSU-REGAN-W11S3G43
4 Miembros
20 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 5
Todo El Tiempo: 645
