Saltar al contenido principal
Sony BDP-BX510 Outer Cover Replacement
Niki Ngosi
Niki Ngosi y 2 otros contribuidores
Última actualización: June 19, 2020
5 - 10 minutos
Fácil
Introducción
Ir al paso 1
This guide will help you remove the outer cover of your Sony BDP-BX510 so that you can start the replacement steps in the other guides.
Qué necesitas
iFixit gana una comisión si finalizas una compra usando estos enlaces.
  1. Sony BDP-BX510 Outer Cover Replacement, Outer Cover: paso 1, imagen 1 de 1
    • Plug in the device to turn it on, then press the eject ( ⏏ ) button to open the tray.
  2. Sony BDP-BX510 Outer Cover Replacement: paso 2, imagen 1 de 2 Sony BDP-BX510 Outer Cover Replacement: paso 2, imagen 2 de 2
    • To remove the tray cover, hold both sides of the tray cover and gently apply a downward pressure.
    • Apply slightly more pressure to the left side until it unhooks then unhook the right side.
    • Close the disk tray by pressing the eject button again, then power off the device and unplug it.
    • Do not use too much force to remove the tray cover as you may break it.
  3. Sony BDP-BX510 Outer Cover Replacement: paso 3, imagen 1 de 2 Sony BDP-BX510 Outer Cover Replacement: paso 3, imagen 2 de 2
    • Turn to the back of the device.
    • Remove the two 7mm Phillips #2 screws.
    • Slide the two plastic covers on both sides of the device towards the back of the device to remove them.
  4. Sony BDP-BX510 Outer Cover Replacement: paso 4, imagen 1 de 3 Sony BDP-BX510 Outer Cover Replacement: paso 4, imagen 2 de 3 Sony BDP-BX510 Outer Cover Replacement: paso 4, imagen 3 de 3
    • Turn the device so you can see the bottom.
    • Unclip the three black plastic clips on the bottom of the device.
    • Unclip one clip on each side of the device.
  5. Sony BDP-BX510 Outer Cover Replacement: paso 5, imagen 1 de 1
    • Slide the cover forward to remove.
Conclusión
Niki Ngosi
Miembro Desde 01/19/20
375 Reputación
3 Guías creadas
Equipo
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 9
Ultimos 30 días: 22
Todo El Tiempo: 243
