Saltar al contenido principal
Sony Alpha NEX-6 Lens Mount Replacement
Clayton Dale
Clayton Dale y 4 otros contribuidores
Última actualización: May 7, 2024
5 - 15 minutos
Moderado
Mejor introducción
Qué necesitas
Herramientas
  1. Sony Alpha NEX-6 Lens Mount Replacement, Finding the Release Button: paso 1, imagen 1 de 1
    • Turn the camera with the lens facing up.
    • Find the lens release button - located along the side of the silver lens mount.
  2. Sony Alpha NEX-6 Lens Mount Replacement, Removing the Lens: paso 2, imagen 1 de 2 Sony Alpha NEX-6 Lens Mount Replacement, Removing the Lens: paso 2, imagen 2 de 2
    • Press and hold the lens release button while rotating the lens counterclockwise.
    • Lift the lens when it is no longer attached to the camera.
    • To replace the lens, align the white dot on the lens with the white dot located on the silver lens mount. (See image two)
    • Insert the lens and rotate it clockwise until it is locked in place.
  3. Sony Alpha NEX-6 Lens Mount Replacement, Lens Mount: paso 3, imagen 1 de 1
    • While dealing with this guide, do not touch the delicate image sensor (the center rectangle encircled by the lens mount).
    • After removing the lens, you will come into contact with the lens mount. Start by unscrewing the four 3.5 mm Phillips #00 screws.
    • The outer lens mount ring can now be removed.
  4. Sony Alpha NEX-6 Lens Mount Replacement: paso 4, imagen 1 de 3 Sony Alpha NEX-6 Lens Mount Replacement: paso 4, imagen 2 de 3 Sony Alpha NEX-6 Lens Mount Replacement: paso 4, imagen 3 de 3
    Herramienta utilizada en este paso:
    • Pay attention to the positioning of the spacer rings for reassembly.
    • For the first (black) spacer ring, use the tweezers to gently pry the ring out of place.
    • Repeat this step for the second (silver) spacer ring.
    • The third image is what the camera should look like after all spacer rings are removed.
  5. Sony Alpha NEX-6 Lens Mount Replacement: paso 5, imagen 1 de 2 Sony Alpha NEX-6 Lens Mount Replacement: paso 5, imagen 2 de 2
    • To remove the inner lens mount ring, remove the two silver 2.0 mm Phillips #00 screws. This will complete the removal of the lens mount.
Conclusión
3 personas más completaron esta guía.
Clayton Dale
Miembro Desde 01/20/15
1,067 Reputación
7 Guías creadas
Equipo
USF Tampa, Team 11-2, Blackwell Winter 2015 Miembro de USF Tampa, Team 11-2, Blackwell Winter 2015
USFT-BLACKWELL-W15S11G2
4 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 8
Ultimos 30 días: 14
Todo El Tiempo: 1,718
