Saltar al contenido principal
Sony α6500 Top Assembly Replacement
Micah Fitzgerald
Micah Fitzgerald y 7 otros contribuidores
Última actualización: May 7, 2024
30 minuto
Moderado
Introducción
Ir al paso 1
If the top of your camera is damaged or broken, this guide will walk you through its replacement. The removal of the top of the camera is also a prerequisite for the replacement of the flash unit, memory card reader, motherboard, viewfinder glass, and other complex components. You will require a JIS 0 screwdriver, JIS 00 screwdriver, JIS 000 screwdriver, tweezers, and opening tools.
Qué necesitas
Herramientas
Ver más…
  1. Sony α6500 Top Assembly Replacement, Battery: paso 1, imagen 1 de 1
    • Verify the camera is powered off by setting the switch to OFF.
  2. Sony α6500 Top Assembly Replacement: paso 2, imagen 1 de 2 Sony α6500 Top Assembly Replacement: paso 2, imagen 2 de 2
    • Flip the camera upside down.
    • Slide the battery compartment lock to OPEN to unlock it.
  3. Sony α6500 Top Assembly Replacement: paso 3, imagen 1 de 2 Sony α6500 Top Assembly Replacement: paso 3, imagen 2 de 2
    • Push the blue lever aside to release the battery.
  4. Sony α6500 Top Assembly Replacement: paso 4, imagen 1 de 1
    • Remove the released battery from the compartment.
  5. Sony α6500 Top Assembly Replacement, Top Assembly: paso 5, imagen 1 de 2 Sony α6500 Top Assembly Replacement, Top Assembly: paso 5, imagen 2 de 2
    • To access the back of the camera remove the screws attaching the LCD screen hinge to the camera body.
    • Remove four 3 mm JIS 000 screws.
    • Remove one 3 mm JIS 00 screw.
    • After dismounting the screen hinge be careful to avoid tearing the black wire ribbon connecting the screen to the camera body.
  6. Sony α6500 Top Assembly Replacement: paso 6, imagen 1 de 2 Sony α6500 Top Assembly Replacement: paso 6, imagen 2 de 2
    • Grasp the viewfinder eyecup; slide it up and off the viewfinder.
  7. Sony α6500 Top Assembly Replacement: paso 7, imagen 1 de 3 Sony α6500 Top Assembly Replacement: paso 7, imagen 2 de 3 Sony α6500 Top Assembly Replacement: paso 7, imagen 3 de 3
    • Press the flash popup button on the back of the camera.
    • Remove one 5 mm JIS 00 screw from inside the flash compartment.
    • Remove one 4 mm JIS 00 screw.
  8. Sony α6500 Top Assembly Replacement: paso 8, imagen 1 de 3 Sony α6500 Top Assembly Replacement: paso 8, imagen 2 de 3 Sony α6500 Top Assembly Replacement: paso 8, imagen 3 de 3
    • To remove the top of the camera you must remove the back first.
    • Remove the 2.5 mm JIS 00 screw from the side of the camera near the viewfinder.
    • Use the opening tool to pry off the small cover.
    • Remove two 2.5 mm JIS 00 screws from underneath the cover.
    • Remove a 5 mm JIS 00 screw from underneath the cover.
  9. Sony α6500 Top Assembly Replacement: paso 9, imagen 1 de 2 Sony α6500 Top Assembly Replacement: paso 9, imagen 2 de 2
    • Remove three 2.5 mm JIS 0 screws from the back face of the camera.
    • Remove one 4 mm JIS 00 screw from the underside of the lip that overhangs the back of the camera.
  10. Sony α6500 Top Assembly Replacement: paso 10, imagen 1 de 1
    • Remove four 4 mm JIS 0 screws from the bottom of the camera.
  11. Sony α6500 Top Assembly Replacement: paso 11, imagen 1 de 2 Sony α6500 Top Assembly Replacement: paso 11, imagen 2 de 2
    • Flip the battery lock switch to open and open the battery compartment.
    • Remove three 2.5 mm JIS 00 screws from the top of the battery compartment.
    • You may need a longer or thinner screwdriver to reach the screws in the battery compartment.
  12. Sony α6500 Top Assembly Replacement: paso 12, imagen 1 de 2 Sony α6500 Top Assembly Replacement: paso 12, imagen 2 de 2
    • Use the plastic opening tool to begin prying off the back of the camera from the side.
    • Continue to loosen the back until you can open it from the bottom.
  13. Sony α6500 Top Assembly Replacement: paso 13, imagen 1 de 3 Sony α6500 Top Assembly Replacement: paso 13, imagen 2 de 3 Sony α6500 Top Assembly Replacement: paso 13, imagen 3 de 3
    Herramienta utilizada en este paso:
    • Open the back of the camera.
    • Use tweezers to remove two ribbon connectors from underneath the back. One connects to the LCD display and the other connects to the right side behind the battery compartment.
    • Ribbon connectors can tear easily. Grasp the plastic ends (not the ribbon) when removing.
  14. Sony α6500 Top Assembly Replacement: paso 14, imagen 1 de 3 Sony α6500 Top Assembly Replacement: paso 14, imagen 2 de 3 Sony α6500 Top Assembly Replacement: paso 14, imagen 3 de 3
    • Use the plastic opening tool to peel down the rubber grip around the handle at least 1 cm.
    • The adhesive holding the rubber grip down should be strong enough to reattach when you are done. If not, you may need an adhesive to reglue it.
    • Remove one 3 mm JIS 000 screw from underneath the rubber grip on the right side.
    • Remove one 4 mm JIS 000 screw from the left side.
  15. Sony α6500 Top Assembly Replacement: paso 15, imagen 1 de 2 Sony α6500 Top Assembly Replacement: paso 15, imagen 2 de 2
    • The last screws holding the top on can be accessed once the back of the camera is removed.
    • Remove one 2.5 mm JIS 00 screw from the top next to the flash mount.
  16. Sony α6500 Top Assembly Replacement: paso 16, imagen 1 de 3 Sony α6500 Top Assembly Replacement: paso 16, imagen 2 de 3 Sony α6500 Top Assembly Replacement: paso 16, imagen 3 de 3
    • Insert a long, thin JIS 00 screwdriver through the two holes and into the battery compartment; remove the two 5mm JIS 00 screws inside it.
  17. Sony α6500 Top Assembly Replacement: paso 17, imagen 1 de 2 Sony α6500 Top Assembly Replacement: paso 17, imagen 2 de 2
    • Use the long, thin, screwdriver to remove one 5 mm JIS 00 screw inside the camera accessible below the dials from the back.
  18. Sony α6500 Top Assembly Replacement: paso 18, imagen 1 de 3 Sony α6500 Top Assembly Replacement: paso 18, imagen 2 de 3 Sony α6500 Top Assembly Replacement: paso 18, imagen 3 de 3
    • Use the plastic opening tool to gently lift up the shutter button assembly.
    • Grasp the front grip from the top and bottom and pull it off. It should come off easily with the shutter button out of the way.
    • The shutter button will still be attached by one ribbon cable once the front grip is removed.
  19. Sony α6500 Top Assembly Replacement: paso 19, imagen 1 de 3 Sony α6500 Top Assembly Replacement: paso 19, imagen 2 de 3 Sony α6500 Top Assembly Replacement: paso 19, imagen 3 de 3
    • Remove one 2.5 mm JIS 00 screw from where the shutter button assembly used to be.
    • Remove one 3 mm JIS 00 screw from the side of the camera.
  20. Sony α6500 Top Assembly Replacement: paso 20, imagen 1 de 2 Sony α6500 Top Assembly Replacement: paso 20, imagen 2 de 2
    • Carefully unplug the two ribbon connectors attaching the top assembly to the rest of the camera.
Conclusión
4 personas más completaron esta guía.
Equipo
Cal Poly, Team S11-G5, Regan Fall 2019 Miembro de Cal Poly, Team S11-G5, Regan Fall 2019
CPSU-REGAN-F19S11G5
5 Miembros
14 Guías creadas
Un comentario
Do you know where i should buy this? Especially in Indonesia.
Dimasngehe - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 5
Ultimos 30 días: 26
Todo El Tiempo: 1,300
