Sonos Playbase A Speaker from the Main Array Replacement
Introducción
Ir al paso 1This guide shows how to replace a speaker from the main array of a Sonos Playbase.
Qué necesitas
Herramienta utilizada en este paso:Pro Tech Toolkit$74.95
Turn the Playbase upside down so that the "Sonos Playbase" imprint is face up.
Remove the bottom panel with an Opening Tool by inserting underneath and prying upwards.
Remove the metal plate with a Opening Tool by inserting underneath and prying upwards.
Disconnect the main speaker array from the main board, by pinching and and pulling the tab out.
Remove the four 11mm T-10 screws from the individual speaker that needs replacement, by turning the screws counterclockwise.
