Saltar al contenido principal
Shark ION Robot 750 Charging Dock Motherboard Replacement
corieon downing
corieon downing y 3 otros contribuidores
Última actualización: December 27, 2023
20 - 30 minutos
Moderado
Introducción
Ir al paso 1
If you cannot charge your Shark ION Robot, there may be a problem with the charging dock motherboard, which requires a replacement.
Damage to the charging dock could cause damage to the battery when trying to charge it or even a heat reaction, which could cause fires or other malfunctions.
Qué necesitas
Herramientas
  1. Shark ION Robot 750 Charging Dock Motherboard Replacement, Charging Dock: paso 1, imagen 1 de 1
    • Remove the three Torx T6 screws on the underside of the charging dock.
    • Lift off the lower case.
  2. Shark ION Robot 750 Charging Dock Motherboard Replacement: paso 2, imagen 1 de 1
    • Using a Phillips #0 screwdriver, unscrew the four screws inside.
  3. Shark ION Robot 750 Charging Dock Motherboard Replacement: paso 3, imagen 1 de 2 Shark ION Robot 750 Charging Dock Motherboard Replacement: paso 3, imagen 2 de 2
    • Gently push in the tabs to remove the sensor housing.
  4. Shark ION Robot 750 Charging Dock Motherboard Replacement: paso 4, imagen 1 de 1
    • Unplug the two wires going into the motherboard, then gently lift the motherboard up and out of its slot.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 6
Todo El Tiempo: 113
