Saltar al contenido principal
Samsung WB35F Flash Capacitor Replacement
Sarmad Khan
Sarmad Khan y 4 otros contribuidores
Última actualización: November 25, 2020
15 - 30 minutos
Moderado
Introducción
Ir al paso 1
This guide will give user step by step instructions on how to replace the flash capacitor of the camera.
Qué necesitas
Herramientas
Ver más…
  1. Samsung WB35F Flash Capacitor Replacement, Rear Case: paso 1, imagen 1 de 3 Samsung WB35F Flash Capacitor Replacement, Rear Case: paso 1, imagen 2 de 3 Samsung WB35F Flash Capacitor Replacement, Rear Case: paso 1, imagen 3 de 3
    • The first thing to do will be unscrew all the screws using Phillips #000 Screwdriver.
    • Keep all the screws in order. Black screws goes under the bottom of camera, and the silver screws goes on the sides and inside of the camera.
  2. Samsung WB35F Flash Capacitor Replacement: paso 2, imagen 1 de 2 Samsung WB35F Flash Capacitor Replacement: paso 2, imagen 2 de 2
    • Using the spudger, and plastic opening tool open the casing of camera.
  3. Samsung WB35F Flash Capacitor Replacement: paso 3, imagen 1 de 3 Samsung WB35F Flash Capacitor Replacement: paso 3, imagen 2 de 3 Samsung WB35F Flash Capacitor Replacement: paso 3, imagen 3 de 3
    • Once you open the camera case, you will be able to work on any part of the camera.
  4. Samsung WB35F Flash Capacitor Replacement, Flash Capacitor: paso 4, imagen 1 de 2 Samsung WB35F Flash Capacitor Replacement, Flash Capacitor: paso 4, imagen 2 de 2
    • Caution: Touching the capacitor wires may cause serious injury. Use a capacitor discharge probe to safely rid the capacitors of dangerous charges.
    • Carefully take out the capacitor using the spudger.
  5. Samsung WB35F Flash Capacitor Replacement: paso 5, imagen 1 de 1
    • Disconnect the wire from battery and replace the old battery with new battery.
    • Connect the wires to new battery and put the battery back in terminal.
    • Connect the positive wire to the positive terminal of the battery and negative wire to the the negative terminal of the battery.
Conclusión
Sarmad Khan
Miembro Desde 01/09/15
525 Reputación
5 Guías creadas
Equipo
USF Tampa, Team 1-6, Tanski Winter 2015 Miembro de USF Tampa, Team 1-6, Tanski Winter 2015
USFT-TANSKI-W15S1G6
Miembros de 4
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 13
Ultimos 30 días: 39
Todo El Tiempo: 2,123
