Samsung WB350F Menu/Control Buttons Replacement
Introducción
Ir al paso 1If your control/menu buttons aren't working on your camera, this guide will walk you through replacing them.
Qué necesitas
Herramientas
Using your Phillips #000 Screwdriver, remove one 3.2 mm screw above the menu buttons panel.
Next, remove the two 3.2 mm Phillips #000 screws to the left of the menu buttons panel.
Gently pull the ribbon in order to remove the menu/control button panel.
