Saltar al contenido principal
Samsung Older French Door Refrigerator Condenser Fan Replacement
Bill Gilbert
Bill Gilbert y otro contribuidor
Última actualización: January 30, 2025
30 - 40 minutos
Moderado
Introducción
Ir al paso 1
Use this guide to replace the condenser fan on your older Samsung French door refrigerator.
The condenser fan circulates air over the condenser coils. This cools the condenser coils and allows refrigerant in the coils to liquefy and release heat. The moving air carries the heat away.
If the condenser fan fails, the refrigerator will operate poorly or not at all because it will not be able to get rid of the heat that is released from the condensing refrigerant. It will likely stop cooling and the compressor may overheat and shut down.
The compressor fan is is a fairly tight location, so be prepared to patiently work at removing it and at removing the fan blades.
Qué necesitas
iFixit gana una comisión si finalizas una compra usando estos enlaces.
  1. Samsung Older French Door Refrigerator Condenser Fan Replacement, Unplug your refrigerator: paso 1, imagen 1 de 1
    • Unplug your refrigerator before you begin your repair.
    • If you are testing or repairing the following items, you may also need to shut off and disconnect the water supply:
    • Condenser fan motor
    • Compressor motor and thermal overload device
    • Water supply valve assembly
  2. Samsung Older French Door Refrigerator Condenser Fan Replacement, Unfasten the rear panel: paso 2, imagen 1 de 1
    • Use a #2 Phillips driver to remove the screws securing the rear panel to the refrigerator.
  3. Samsung Older French Door Refrigerator Condenser Fan Replacement, Remove the rear panel: paso 3, imagen 1 de 3 Samsung Older French Door Refrigerator Condenser Fan Replacement, Remove the rear panel: paso 3, imagen 2 de 3 Samsung Older French Door Refrigerator Condenser Fan Replacement, Remove the rear panel: paso 3, imagen 3 de 3
    • Lift the rear panel upward and outward to free the panel the from the tabs at the lower edge.
    • Remove the panel.
  4. Samsung Older French Door Refrigerator Condenser Fan Replacement, Disconnect the condenser fan: paso 4, imagen 1 de 3 Samsung Older French Door Refrigerator Condenser Fan Replacement, Disconnect the condenser fan: paso 4, imagen 2 de 3 Samsung Older French Door Refrigerator Condenser Fan Replacement, Disconnect the condenser fan: paso 4, imagen 3 de 3
    • Locate the condenser fan power and control connector.
    • Grasp the connector, squeeze the locking tab, and pull down on the connector to disconnect it.
  5. Samsung Older French Door Refrigerator Condenser Fan Replacement, Unfasten the condenser fan: paso 5, imagen 1 de 1
    • Use a #2 Phillips driver to unfasten the fan bracket retaining screw.
  6. Samsung Older French Door Refrigerator Condenser Fan Replacement, Free the fan bracket: paso 6, imagen 1 de 3 Samsung Older French Door Refrigerator Condenser Fan Replacement, Free the fan bracket: paso 6, imagen 2 de 3 Samsung Older French Door Refrigerator Condenser Fan Replacement, Free the fan bracket: paso 6, imagen 3 de 3
    • Slide the fan bracket toward you (toward the rear of the refrigerator.)
    • Then slide the bracket about 1/2"-3/4" (15-20 mm) to the left toward the compressor.
  7. Samsung Older French Door Refrigerator Condenser Fan Replacement, Rotate the fan bracket to free it: paso 7, imagen 1 de 3 Samsung Older French Door Refrigerator Condenser Fan Replacement, Rotate the fan bracket to free it: paso 7, imagen 2 de 3 Samsung Older French Door Refrigerator Condenser Fan Replacement, Rotate the fan bracket to free it: paso 7, imagen 3 de 3
    • Rotate the fan bracket clockwise, as shown by the arrows.
    • There is a refrigerant tube (red box) that passes through the bracket. Do not attempt to free the bracket from the tube just yet.
    • The third photo shows the fan bracket pivoting on the refrigerant tube after it has been rotated as mentioned.
    • By rotating the bracket clockwise first, you will be able to then pivot the assembly out of the machinery compartment.
  8. Samsung Older French Door Refrigerator Condenser Fan Replacement, Remove the condenser fan assembly: paso 8, imagen 1 de 1
    • Remove the condenser fan assembly.
  9. Samsung Older French Door Refrigerator Condenser Fan Replacement, Remove the fan blade assembly: paso 9, imagen 1 de 2 Samsung Older French Door Refrigerator Condenser Fan Replacement, Remove the fan blade assembly: paso 9, imagen 2 de 2
    • Insert a flat-blade screwdriver under the fan blade hub.
  10. Samsung Older French Door Refrigerator Condenser Fan Replacement: paso 10, imagen 1 de 3 Samsung Older French Door Refrigerator Condenser Fan Replacement: paso 10, imagen 2 de 3 Samsung Older French Door Refrigerator Condenser Fan Replacement: paso 10, imagen 3 de 3
    • Pry upward with the screwdriver on the fan blade hub.
    • You may find the fan difficult to remove. One tip is to apply the prying force in line with the shaft (vertically) as much as possible.
    • You may find it easier to break the fan free by rotating the screwdriver at first to pry upward.
    • As the fan starts to slide on the shaft, you may also want to put the screwdriver tip further from the hub. Then lift with the shank as you start to remove the fan.
  11. Samsung Older French Door Refrigerator Condenser Fan Replacement: paso 11, imagen 1 de 2 Samsung Older French Door Refrigerator Condenser Fan Replacement: paso 11, imagen 2 de 2
    • Remove the fan.
    • The second photo is for reference for proper motor orientation when reassembling.
  12. Samsung Older French Door Refrigerator Condenser Fan Replacement, Unfasten the fan motor from the assembly: paso 12, imagen 1 de 1
    • Use a #2 Phillips screwdriver to remove the two screws securing the motor to the motor assembly.
    • The picture was taken before the fan was removed
  13. Samsung Older French Door Refrigerator Condenser Fan Replacement, Unfasten the motor bracket from the motor assembly: paso 13, imagen 1 de 2 Samsung Older French Door Refrigerator Condenser Fan Replacement, Unfasten the motor bracket from the motor assembly: paso 13, imagen 2 de 2
    • Use a flat blade screwdriver to pry each motor bracket clip from the motor assembly and unfasten the motor bracket.
  14. Samsung Older French Door Refrigerator Condenser Fan Replacement, Free the motor and bracket from the motor assembly: paso 14, imagen 1 de 2 Samsung Older French Door Refrigerator Condenser Fan Replacement, Free the motor and bracket from the motor assembly: paso 14, imagen 2 de 2
    • Reposition the motor and bracket from the motor assembly by pulling it straight off the assembly in line with the motor shaft.
    • Take care not to damage the wiring which is still connected to the motor.
  15. Samsung Older French Door Refrigerator Condenser Fan Replacement, Disconnect the motor from the motor assembly: paso 15, imagen 1 de 3 Samsung Older French Door Refrigerator Condenser Fan Replacement, Disconnect the motor from the motor assembly: paso 15, imagen 2 de 3 Samsung Older French Door Refrigerator Condenser Fan Replacement, Disconnect the motor from the motor assembly: paso 15, imagen 3 de 3
    • Squeeze the connector retaining tab to release the connector.
    • Pull the connector straight off of the motor to disconnect it.
Conclusión
Repair didn’t go as planned? Ask our Answers Community for help.
Bill Gilbert
Miembro Desde 06/30/22
37,413 Reputación
261 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
118 Miembros
19,418 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 7
Ultimos 30 días: 12
Todo El Tiempo: 72
